Old 16-02-10, 07:24 PM   #1
ibriggs
Default Difficulty tightening rear axle nut
Hi All
First post after buying a K8 SV650 Sport in December last year, but have been busy reading the great advice on the site.
Have just adjusted my chain for the first time and I am finding it a right pain to tighten the axle nut to the right torque without the spindle just turning. This is despite trying to hold a spanner on the spindle side. It is sending me crazy and the 22mm spindle nut is so hard to grip.
Has anyone had the same problem and worked out a neat solution without getting someone else to help - impossible to get any of my family in the garage in this weather!
Any tips appreciated.
Ian
Old 16-02-10, 07:56 PM   #2
Dicky Ticker
Default Re: Difficulty tightening rear axle nut
Socket and bar/extension bar -let it turn till on the ground,hold it with your foot from the back of the bike
Socket and power bar on the other side[Better if you have a torque wrench] and tighten up as required
Surely you can do it up till it is starting to tighten without any problem
Old 16-02-10, 08:02 PM   #3
ibriggs
I think my torque wrench might be knackered as the bar/socket on off-side can't keep gripped to the spindle nut whilst I turn my torque wrench on the axle nut (set to 65nm of course).
Old 16-02-10, 11:59 PM   #4
Spanner Man
The shallow head on the spindle is a pain to grip. A good quality 6 sided 22mm socket in half inch drive will help here, & practise of course.
The torque on a pointy spindle should be 100nm, 65nm was for the curvy model.
Cheers.
Spanner Man
rear axle nut torque? DaveP SV Talk, Tuning & Tweaking 16 18-09-11 02:41 AM
Rear Axle Nut TheOnlyNemesis SV Talk, Tuning & Tweaking 9 19-01-10 08:26 PM
Rear wheel axle nut sweepdoggydog Stuff Wanted 0 25-04-09 07:47 PM
Rear axle nut alternatives? arcdef SV Talk, Tuning & Tweaking 11 08-04-09 03:03 PM
What is the size of the Rear Axle nut? mordecai SV Talk, Tuning & Tweaking 4 02-05-05 07:57 PM
