Old 18-02-10, 11:22 AM   #1
Todge
Default Old Headstock Bearing Races Needed
Hi guys,
Im in need of a set of headstock bearing races for a Curvy. An old set which will never be used again would be ideal.
Let me know if you have anything suitable.
Thanks!
Old 18-02-10, 11:41 AM   #2
21QUEST
21QUEST's Avatar
Default Re: Old Headstock Bearing Races Needed
Hiya,
I might have some somewhere.
I assume, it doen't matter if they are OE or the Taper ones...
Ben
Nemo me impune lacessit.
Old 18-02-10, 01:03 PM   #3
Todge
OE Bearings?
I just need some standard Taper races.
Old 18-02-10, 01:30 PM   #4
21QUEST
21QUEST's Avatar
The Standard(original ) races are not Tapered
Ben
Old 18-02-10, 04:57 PM   #5
Todge
Tapered races are whats in there, so thats what i require.
Old 18-02-10, 06:33 PM   #6
You after some knackered ones to use as driver? Or some to actually fit?
Old 19-02-10, 11:02 AM   #7
Todge
Some which fit. There to put into a frame Im making, and just need some to use while Im mocking it all up.
Old 19-02-10, 11:12 PM   #8
21QUEST
21QUEST's Avatar
Got an unused lower one for sure. I shall have a looky tomorrow for a top.
PM us a reminder if not heard from me by 4.00PM
Ben
Headstock bearing play boot Bikes - Talk & Issues 6 20-10-09 01:30 PM
Anyone with a headstock stand? arcdef Guildford Massive 6 17-08-09 11:32 PM
Headstock bearing/fork knock swinging_simian SV Talk, Tuning & Tweaking 6 21-08-08 08:44 AM
Headstock stand £40 tomjones2 For Sale - SV's and SV related items 3 29-11-07 05:09 PM
Headstock bearings brolong22 SV Talk, Tuning & Tweaking 28 26-07-05 04:48 PM
