Old 19-02-10, 03:07 PM   #1
scottjames
Default Fuel light query.
2001 curvey 650
does the fuel light flash then go solid or just flash?
This is the second time she's caught me out!!
Scott
Old 19-02-10, 03:09 PM   #2
Geodude
Geodude's Avatar
Default Re: Fuel light query.
My 99 naked fuel light flashes until tank almost empty then goes solid
Old 19-02-10, 03:19 PM   #3
Taipan
Taipan's Avatar
Mine flashes first and then goes solid. With my consumption (40-45mpg if lucky) its about 30 mile range in total with the last 10 on solid.
Old 19-02-10, 06:03 PM   #4
pce13
mine just flashes then conks out no solid
Old 19-02-10, 06:04 PM   #5
phi-dan
phi-dan's Avatar
Had similar trouble myself.
The fuel sensor has two thermistors (ntc) held at fixed heights in the tank. The current supplied to the thermistors causes them to warm up and reduce resistance, however, the fuel disipates the heat which keeps resistance high. Once the fuel level drops below the top thermistor, it heats up and drops resistance to 0 which triggers the flashing light on the dashboard. After the fuel drop below the second thermistor the light goes solid (note 1). However (and this is the part that caught me out) if the thermistors have degraded/broken, then they won't drop resistance enough to trigger the lights on their own, but together they can trigger the flashing light. You think you have 30ish miles to go, the bike cuts out after 10
The solution is to either replace the sensor unit, or to attempt a repair (note 2). On one of the Goldwing forums in America, there is a chap (http://www.duaneduncan.com/low%20fuel%20sensor.html, and also http://www.electronicspoint.com/ther...k-t123318.html) who has found that 1kOhm NTC thermistors will be adequate to replace the stock ones. I haven't tried this yet, but will do when I can get together an electrical parts order that comes to more then the postage costs!
Note 1: it doesn't matter which sensor is uncovered first, the light will flash with one thermistor uncovered then go steady with two (ooer).The test procedure in the Suzuki service manual involves dunking the sensor "upside down" into a container of fuel
Note 2: only attempt a repair if you are competent with electronics, as electricity and fuel can go bang (albeit highly unlikely in this application) and I have no desire to see you toast your bike
Was: Red curvy S: crash bungs, double bubble screen, fenda extenda, HEL front lines, OEM belly pan
Now: Blue FZ6 Fazer
phi-dan is offline   Reply With Quote
Old 19-02-10, 06:49 PM   #6
scottjames
Cheers guys, so I think the concensus is tht it's meant to flash then go solid. However mine didn't, I pushed it and pushed it then after 15 miles with the light flashing it cut out. I mite have a spare sensor if not then I'm an apprentice at bae I'm sure my tutor could help me out.
Thank you
Scott
Old 19-02-10, 08:14 PM   #7
svrich
Mine is flash then solid. I can get a further 15 ish miles on a solid light but thats with a 55mpg average.
Old 19-02-10, 08:45 PM   #8
Grant66
Grant66's Avatar
Was there a few weeks ago, there was a very nice bronze coloured pointy with twin exhausts in the car park (the one near reception). Is that yours?
Grant66 is offline   Reply With Quote
Old 20-02-10, 12:36 PM   #9
scottjames
nope not mine, ive got a black curvey. whch site was you at? scott
Old 28-02-10, 02:32 PM   #10
kevo115
is your bike a k3? if so it does not have the 2 stage sensor. just a solid light. it caught me out once.
curvy - fuel tank mounting query flymo SV Talk, Tuning & Tweaking 15 03-06-09 12:15 PM
Fuel Light Skripthor SV Talk, Tuning & Tweaking 10 10-08-08 10:01 PM
gas light?(that'll be fuel warning light) Spanish Fly SV Talk, Tuning & Tweaking 9 08-06-07 05:45 PM
Replacement fuel light / fuel tap riktherider SV Talk, Tuning & Tweaking 7 14-05-07 06:41 PM
query on connecting new intercom to tail light circuit Johnsilver SV Talk, Tuning & Tweaking 3 28-05-05 04:57 PM
