Old 21-02-10, 06:04 PM   #1
Default Airbox refitting tips
As the bike is nearly back in one piece, are there any tips in refitting the airbox on a curvey.
I removed it to get to the ingnition connector in front of the airbox
Old 21-02-10, 06:07 PM   #2
Default Re: Airbox refitting tips
Leave the boots on the carbs and just pop it down onto the lips. Get rear one aligned then push it back a little, then push down and it pops on. Then just reach inside and make sure the lip is rolled over the right way all around both carb inlets.
Old 21-02-10, 06:09 PM   #3
Do you use any lube, vasaline or red rubber grease to ease the refitting
Old 21-02-10, 06:17 PM   #4
Nah there's usually bit of oil on them from the airbox anyway.
If they're very cold it can be a pain.
Old 21-02-10, 06:19 PM   #5
Yes, this is the problem at the mo, its bloomin freezing. Although not as cold as your place by the sound of it
Old 21-02-10, 06:22 PM   #6
They should be ok though, just flexing them around warms them up. Give it a go it's not massively hard.
Old 21-02-10, 06:25 PM   #7
Yep, its the first time I've taken the airbox off. Its one of those things there's a knack to doing it. Cheers YC
Old 21-02-10, 06:27 PM   #8
fastdruid
fastdruid's Avatar
Hmmm, I always do it with the boots on the airbox and reach inside to push them over the carbs.
Hot air gun or some other kind of heat works wonders though.
Druid
Old 21-02-10, 06:46 PM   #9
That works too, just then you have to mess with the screws with less access. Many ways to skin a cat.
Old 21-02-10, 06:52 PM   #10
fastdruid
fastdruid's Avatar
Long screwdriver and making sure the screws have plenty of copperslip.
Druid
Refitting Original Exhaust for MOT Mattnut SV Talk, Tuning & Tweaking 2 16-08-09 05:54 PM
Refitting standard exhaust? Bris-Rob Bikes - Talk & Issues 10 22-02-09 11:51 AM
Refitting indicator cap woes chakraist Bikes - Talk & Issues 0 18-09-08 04:57 PM
Refitting rear Seat amxor Bikes - Talk & Issues 9 13-09-07 04:39 PM
refitting front seat karen SV Talk, Tuning & Tweaking 4 23-09-04 08:08 AM
