Old 21-02-10, 07:33 PM   #1
stamasman
Default brembo master cylinder
Hi i'm lookin some info about brembo master cylinders I was told the 19/20mm ratio is the 1 to go for.
Any 1 know about these
Old 21-02-10, 09:13 PM   #2
zadar
Default Re: brembo master cylinder
19x20 is what I have and like it. If you like less lever travel and hard 20 is the one. 18 is more travel and softer. If you buy 19x18 you can have both. If you don't like lever travel you can simply put 20 lever on it.
Old 21-02-10, 09:20 PM   #3
stamasman
think i'll go for the 19x20 how do you rate the brembo over the stock master cylinder
Old 21-02-10, 11:10 PM   #4
zadar
It gives better feel than stock one. It all depends what you like. There is nothing really wrong with properly working stock one, it will stop your bike. It is all about feel and personal preference.
GSX-R master cylinder. phil24_7 SV Talk, Tuning & Tweaking 14 09-01-08 02:04 PM
Brembo radial master cylinder kcowgergmm SV Talk, Tuning & Tweaking 8 04-12-07 01:51 PM
Where to get brembo master cylinder parts? northwind SV Talk, Tuning & Tweaking 13 10-09-07 06:13 PM
Master Cylinder phil24_7 Bikes - Talk & Issues 1 28-07-07 11:12 PM
Brembo master cylinder vs. OEM the oaf SV Talk, Tuning & Tweaking 12 30-04-06 06:35 PM
