Old 22-02-10, 10:39 PM   #1
sauluk
Default refitting baffle
I drilled the rivet out to remove the baffle but now want it back in. The noise is becoming a pain now.
What size bolt do I need to refit? assuming I can just use a shallow bolt and nut? Or should I wait until I'm at the in laws for him to rivet it in?
Old 23-02-10, 04:04 PM   #2
Son of a beesting
Default Re: refitting baffle
Strange I was thinking of this last night, I want to take mine out and would like to be able to put it back at some point.
*watches thread*
Old 24-02-10, 12:44 AM   #3
Philip663
I drilled through my rivet and now when i want to put it back on i have a small nut and bolt which fits and works perfectly
Old 24-02-10, 06:40 AM   #4
Mr_Chin
PS. I hope you also used a spring washer or thread lock, as the vibrations from the exhaust will rattle the nut and bolt loose...
- it's not nice having a baffle down the exhaust!
Happy fishing if it does!
Chin
Old 06-03-10, 11:56 AM   #5
metalhead19
I take it the general idea most people have is to remove the baffle?
I have a scorpion street extreme and tried it without the baffle and couldnt decide if it was too loud or not (as in loud enough to draw attention from police)
Old 06-03-10, 03:16 PM   #6
monkey
Have you tried putting a nut and bolt in that fill the hole?
If you have a 6mm hole, fit an m6 bolt. An 8mm hole, an m8. You should use a spring washer too as has been mentioned. .
Airbox refitting tips maviczap SV Talk, Tuning & Tweaking 14 24-02-10 06:42 PM
Refitting Original Exhaust for MOT Mattnut SV Talk, Tuning & Tweaking 2 16-08-09 05:54 PM
Refitting indicator cap woes chakraist Bikes - Talk & Issues 0 18-09-08 04:57 PM
Refitting rear Seat amxor Bikes - Talk & Issues 9 13-09-07 04:39 PM
refitting front seat karen SV Talk, Tuning & Tweaking 4 23-09-04 08:08 AM
