Old 05-03-10, 12:46 AM   #1
allantheboss
Default "Best" revs to change gear at?
Such thing as a "Power band", where is it on a K2 SV?
Best revs to change from each gear? Like, if I was drag racing for example, so for best continuation of acceleration?
Old 05-03-10, 03:03 AM   #2
barwel1992
Default Re: "Best" revs to change gear at?
i shift about 10k on my k3 if i gunning it
just remember lean over the front in 1st n 2nd and pin the throttle, i used to be fairly gentle on the throttle in 1st n 2nd as the front would lift and wobble but then started leaning over the front and found you can rely give it the beans
Old 05-03-10, 07:59 AM   #3
Alpinestarhero
I rarely go above 7000 rpm when in london, dosnt seem like much point! Out on the country roads, if I'm blatting it, then up to about 9500. I think most of the torque is made between 5000 and 8000 rpm, so if you can keep it in this zone then you'll have a responsive throttle.
I don;t think there is a pwoer band as such, but the first day i rode my SV unrestricted, i did notice a suuurrrrge of power above 7500 rpm, I giggled like a naughty schoolboy. I don;t feel that rush of power anymore though, it feels like one long lovely wave of rumbly goodness all the way to the redline. I guess I was spoilt by the bandit i had for a bit, which really did take off at 8500 rpm!
Old 05-03-10, 10:43 AM   #4
Neeja
If you're out for a spirited ride, try to keep it between 7000 and 9500 rpm. If out for a bimble you never need to go over 6-7k
Old 05-03-10, 11:31 AM   #5
allantheboss
Yeah, a actually normally change up each time at around 7500. I was curious as to whether it differs between gears? As it's still restricted, I guess Im not gaining as much speed in revs over about 8000/8500 (Or at least thats how it feels)(so best to change up from here)?
Old 05-03-10, 12:57 PM   #6
Neeja
If it's restricted then I wouldn't bother going above 7500 at all
Old 05-03-10, 02:08 PM   #7
chris8886
chris8886's Avatar
for a restricted K2 it's worth going to 9000 before banging in the next gear if you're on a track day or something. there is a little bit there to be used and use it i did on TD's when i was resricted.
AR08 to AR13-QUALITY!
Old 05-03-10, 03:01 PM   #8
About 9500 on stock bike, there's not much left above that.
Old 05-03-10, 03:40 PM   #9
I change gear between 5 and 6k.
I don't believe in revving the knackers off my bikes. Many an arguement I have had about how harshly or not to ride a bike, but I like my bike purring not screaming
Don't think I've ever gone over 7k!
Old 05-03-10, 03:46 PM   #10
fastdruid
fastdruid's Avatar
10.5, preload the lever and use the limiter as a crude quickshifter.
Druid
Scorpian Oval "Flame effect" exhaust damaged looking for a change! sv_rider1990 SV Talk, Tuning & Tweaking 5 23-06-08 07:13 AM
Indicator housing/shell & "gear lever"? ooger Stuff Wanted 14 13-11-07 02:21 PM
"Trick" Gear Lever Pointy svdemon For Sale - SV's and SV related items 7 04-11-07 02:12 PM
Makes a change from "Didn't see you mate" Red ones Idle Banter 4 06-02-06 07:54 PM
