Just been quoted £185 by a Suzuki dealer for a K3 Regulator/Rectifier
![]() Has anybody ever thought about using readily available car parts to piece one together at a fraction of the cost? Regulator here: http://cgi.ebay.co.uk/LUCAS-ACR-ALTE...item4836193b26 Rectifier here: http://cgi.ebay.co.uk/LUCAS-ACR-ALTE...item48352cf94c The diodes on the reftifier are rated at 45 amps, so should easily cope with output of SV650 alternator. Any thoughts? Tim |
CBR600RR reg rec... £40 or so on ebay and bolts into same place
09 Fireblade one, doesn't bolt in the same place (bigger) but under the seat and does a cracking job, about 40 quid as well
The Sick Man
http://www.bbbikeshop.co.uk/acatalog...Rec_s_150.html
SV650 Curvey RG85 SV650 Pointy RG851 (aparently but i guess the RG85 should work fine) cheep new and the best option rather than playing around
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#5 | |
last one I used was from a GSXR. plentiful on ebay. I got mine for £10 plus post
Flickr: http://www.flickr.com/photos/croozenooze/ Facebook : https://www.facebook.com/colin.hughes.1213?ref=tn_tnmn Yoo Toob https://www.youtube.com/channel/UCjG...eMWUx4Ud2dK-yA |
Trick is buying a rec/req off of Ebay that works though. Some unscrupulous sellers may just out their old knackered one
![]() Certainly a tenners cheap if you get a result though ![]() |
#8 | |
More than once an owner has brought me a bike that doesn't charge and which has had the regulator replaced with a second hand one - which doesn't work either. Now this may just be a coincidence, but the regulators in such cases have been those usually fitted to Hondas. The unfortunate assumption that Honda regulators are angels breath and must be an improvement his proven incorrect. Or peharps it means Honda owners are unscurpulous thieves? Discuss Anyway, whilst I have often fitted S/H parts to peoples bikes, (at their request only), for many people a new part is a better and more certain option.
#9 |
The car part method may not work. Turns out bike alternators use fixed magnets, whereas car alternators use electro-magnets, I believe the voltage regulation works in a different way.
Tim. |
#10 |
Yeah, car alternator uses a field coil so you only get as much charge out as you need. Bike alternators run all out all the time.
rectifier/regulator | Ceebl | SV Talk, Tuning & Tweaking | 11 | 29-06-09 12:56 PM |
Regulator Rectifier | GeneticBubble | SV Talk, Tuning & Tweaking | 4 | 25-04-09 01:42 PM |
I need a Rectifier / Regulator. | Marv | Stuff Wanted | 3 | 19-08-08 12:43 PM |
Regulator/Rectifier? | Biker Biggles | SV Talk, Tuning & Tweaking | 22 | 31-05-07 08:55 PM |
Regulator/Rectifier | Steve T | SV Talk, Tuning & Tweaking | 3 | 10-10-04 10:34 PM |
