Old 25-03-10, 11:50 AM   #1
ShadFX
Default More electrical fun! Dimming lights?
Hi All
Need some quick suggestions - my lights dim ever so slightly when I give the bike throttle, and then brighten up again the minute its sat back down at idle!?!? The difference is noticeable when parked up against a wall if your looking for it, not noticeable when riding.. Even so - its meant to be the other way around!!
Only conclusion I could draw was:
Dodgey wiring
Wrong wattage bulbs
Conked alternator
Have replaced the reg/rec and this has fixed my charging issue, just gotta fix this and she will be like new
Ideas please
Thanks
Old 25-03-10, 11:53 AM   #2
Default Re: More electrical fun! Helllp -.-
You sometimes get dimming as the regulator kicks in as the voltage rises.
Check the charging rate with a multimeter and if it is within limits don't worry about it.
Old 25-03-10, 11:56 AM   #3
ShadFX
Chris - that makes perfect sense. Gonna go out and get some brighter bulbs - I did a whole trip home on full beam last night and didnt get flashed once :S
No side lights, brake lights, rear lights and dashboard lights Shona Bikes - Talk & Issues 25 13-11-09 11:07 PM
Funny problems with engine speed and lights dimming Binky SV Talk, Tuning & Tweaking 6 15-07-08 08:20 AM
Electrical problem - Rear lights and dash. Habitual Lurker SV Talk, Tuning & Tweaking 6 08-05-08 10:28 AM
Electrical Problem! BigB SELKENT 10 15-01-08 10:34 AM
Electrical help plz? Bikerz SV Talk, Tuning & Tweaking 1 21-07-05 11:38 AM
