Old 25-03-10, 12:46 PM   #1
ShadFX
Default Higher gearing for the SV
Hi all
I do mostly dual carriageway / motorway miles on my way in to work (15 / 16 miles out of the 20) and was looking at gearing the SV up slightly (just so I can sit at about 5K RMP at 75 mph) - but im worried if I pop the front sprocket up a tooth and the rear sprocket down a tooth (equivelent to downing 4 teeth at the rear if i read the other posts right..) that it will ruin the way the bike handles.....
Any ideas or has anyone actually done this?
Thanks
Old 25-03-10, 12:48 PM   #2
Default Re: Higher gearing for the SV
I've had a brief go on Dizzyblondes bike, that's got a tooth up on the front. It's alright just not going to set your head on fire coming out of slow corners.
Old 25-03-10, 12:49 PM   #3
ShadFX
Chris - do you know what kinda RPM the bike sits at at around 70 MPH?
Old 25-03-10, 12:55 PM   #4
Dunno, have a look on gearing commander and play around.
I went opposite way on mine, added 3 teeth to rear, sat at 9k rpm on motorway. It would still do 135 indicated and was loads better than stock around twisties.
Gearing commander reckons you're doing 4999rpm at 70 with stock S gearing, with 16/43 you'd be doing 4580 rpm.
Old 25-03-10, 01:45 PM   #5
if its faired go for one tooth up on front and the standard on the rear.
I shall just look at my specifics...won't be a mo.
ok 44 rear. 16 front.
order a 1998-1999 front sprocket for a GSX-R 750...info from previous owner.
at 90 mph you get approx 6k revs. HTH
Any more info, I'd be happy to oblige, after all most go the opposite way and just assume how things behave.
Old 25-03-10, 01:52 PM   #6
Stu
Trinity
Stu's Avatar
I've got 16/44.
It's fine for what you want
Old 25-03-10, 02:03 PM   #7
ShadFX
Thanks for all the info guys They dont actually need doing yet and its more of an annoyance than anything.. Will jot down the info and make sure I tuck it away for when I need it Thanks!
Old 25-03-10, 02:05 PM   #8
B and C express do sprockets if you ask for "an SV650 one, but with x amount of teeth".
Old 25-03-10, 02:12 PM   #9
embee
embee's Avatar
I have 16/44 (+1 g/box and std rear) on my curvey S. Standard length chain still fits.
It suits my riding style, prefer the more relaxed feel, and I don't keep looking for 7th gear. Don't expect any significant difference in economy.
Old 25-03-10, 02:31 PM   #10
Just going on whats on my bike, but its so good on chains and sprockets I can hardly say I'll be needing to know where to get em....for agggggeeeees. Still wondering when I'll be adjusting the chain for the third time in three years
I notice fuel efficiency more on serious long distance riding up and down the motorway. As I have two bikes to compare, I notice a couple of quid or three difference. Although I suppose it also goes on a persons riding style too.
Is there any way of revving higher ? boo86 SV Talk, Tuning & Tweaking 13 28-02-09 04:55 PM
Higher bars on an N aermacchi SV Talk, Tuning & Tweaking 1 07-07-08 05:11 PM
Higher bars... MikeC SV Talk, Tuning & Tweaking 12 25-12-06 08:56 PM
HIGHer Risers rcmark Bikes - Talk & Issues 2 16-07-05 10:57 AM
Higher bars. BURNER SV Talk, Tuning & Tweaking 7 12-07-05 03:20 PM
