Old 06-04-10, 10:46 PM   #1
ronscotty
Default GSXR forks - which oil?
a set of gsxr 600k7 front forks in a k6 650 what is the best oil to use and how much to put in them .cheers
Old 07-04-10, 01:07 AM   #2
rictus01
rictus01's Avatar
Default Re: front forks
the oil viscosity is a personal choice for speed and feel, as long as the spring weight is correct for you and the static sag is setup, then the the oil is your choice anything from 5w to 15w I'd suggest, as to air gap (how much oil to use) refer to the manual for that bike (the GSXR), a little under won't make much difference, but to much over will lead to a hydrolic lock and could pop the seals.
Cheers Mark.
Old 07-04-10, 08:30 AM   #3
Default Re: GSXR forks - which oil?
Mark, 15W, are you serious? They will be like iron and not return at all.
I like silkolene RSF5, but something around 5 or 7w designation is OK. Idea with cartridge forks like that is you keep the oil the same and change the valving if you need to change behaviour.
http://www.peterverdonedesigns.com/i...osity-Data.gif
here is table. pick one around 25cSt
Old 07-04-10, 10:24 AM   #4
jambo
jambo's Avatar
Find out what the reccomended viscocity for the forks on the GSXR is, and then pick something close to "suzuki" 15w/10w/5w as needed. set them to standard for a GSXR and then adjust as needed. I've found the PJ1 oil stocked by my local bike shop is a pretty dead on match for OE suzuki / kawasaki stuff using the peter verdone link posted by YC.
Jambo
Fitting GSXR front mudguard to GSXR USD forks maviczap SV Talk, Tuning & Tweaking 1 20-02-10 10:05 PM
GSXR 750 k4 wheel with GSXR 600 K7 forks Bunks Bikes - Talk & Issues 12 05-05-09 06:36 PM
K7 GSXR 600/750 or K8 GSXR 1000 Forks shelleyamy SV Talk, Tuning & Tweaking 17 04-07-08 07:51 AM
gsxr k6/7 forks maff SV Talk, Tuning & Tweaking 7 10-02-08 06:02 PM
which GSXR for forks svrash SV Talk, Tuning & Tweaking 29 15-02-06 09:15 AM
