Old 07-04-10, 06:20 PM   #1
jonny.boyd
jonny.boyd's Avatar
Default Tickover low and erratic.
Hiya all.
Right this has only started happening this week. Basically i'll start up the bike, turn up choke to get the engine warmed up a bit. When it's been revving away for a bit i'll reduce the choke and set it so it's idling around 1.5k - 2k RPM. I'll then drive away quite happily. i'll then completely drop out the choke after a couple of minutes of riding. I then find that for the first 30 mins or so of driving when i pull to a stop the revs drop down to 1k rpm (i can feel that bike struggling to keep turning over) and wen driving along can feel the bikes acceleration act bike weird (when cruising). After about 30mins of riding the revs return to normal and the bike will then idle at around 1.5k and bike sounds and acts like normal. I know this sounds like a tiny problem but it's only just started doing it this week (so its making me worry).
Any advise would be greatly appreciated to put me out of my misery!
[Bikes a Curvy, 2000 model]
jonny.boyd is offline   Reply With Quote
Old 07-04-10, 06:37 PM   #2
sunshine
Default Re: Small issue with SV
balance the carbs should solve the problem i believe.
Old 07-04-10, 06:39 PM   #3
gettin2dizzy
+1 to balancing carbs.
Old 07-04-10, 06:41 PM   #4
jonny.boyd
jonny.boyd's Avatar
Thankyou for the incredibly prompt replies!! Since i'm in no way mechanically minded and don't have the tools.. how much of my money would i expect the garage to steal if i got it done at one?
Old 07-04-10, 06:43 PM   #5
sunshine
i dont pay for it they spend 15 minutes doing it when there quiet.
Old 07-04-10, 06:44 PM   #6
husky03
too much-get yourself a set of carbtune gauges , about 45 quid and you'll be able to do them in future
http://cgi.ebay.co.uk/Carbtune-2-cyl...item1c0d57fcf8
Old 07-04-10, 06:47 PM   #7
bobbleheadbarne
just got mine done looking at 150 dont go to the dealer they will screw you runs well better now as i had the same problem i only use choke now for 2mins and idles 1300rpm
Old 07-04-10, 06:51 PM   #8
gettin2dizzy
£150! Ouch!
Ask around, someone on here may be able to help. I would happily do it but you're miles away
Old 07-04-10, 06:52 PM   #9
bobbleheadbarne
sorry that was with new shims for top overhaul
Old 07-04-10, 06:53 PM   #10
jonny.boyd
jonny.boyd's Avatar
So pretty expensive then!! Anyone around Midlands / Home Counties areas that has the balancing kit? I would pay for your time... i just don't think i'd be able to do it myself (dont have the confidence).
erratic Idle & jerky low speed performance Interceptor SV Talk, Tuning & Tweaking 4 01-06-09 10:26 PM
Erratic idle cat0020 SV Talk, Tuning & Tweaking 11 22-10-08 08:36 PM
Erratic speedo and tacho, engine very hot. chakraist SV Talk, Tuning & Tweaking 2 17-07-08 03:19 PM
Erratic Speedo? cowie SV Talk, Tuning & Tweaking 4 14-06-07 10:12 PM
Faulty/erratic speedo reading SV1000 ginger SV Talk, Tuning & Tweaking 5 03-05-05 10:05 AM
