Old 08-04-10, 09:12 AM   #1
plowsie
Default Router to Router Wirelessly - Can it be done?
I'm trying to figure a way round throwing cables all over the house and not splash out on a wireless receiver on the xbox and came up with this maybe...
I have a spare wireless router, could I connect this up to the xbox with the ethernet cable and then connect wirelessly to the actual real wireless router downstairs that we all access from our PC's in the house to use the internet?
Old 08-04-10, 09:35 AM   #2
keith_d
keith_d's Avatar
Default Re: Router to Router Wirelessly - Can it be done?
I think 3-com offered router-to-router connectivity on one of their models. But it was limited to other units of the same type so pretty much useless for most of us.
I suspect your best bet will be to look for an access point on Fleabay which is effectively a wireless to 10-baseT bridge.
Old 08-04-10, 09:51 AM   #3
gettin2dizzy
yeah you can with a lot of routers. Just set it up as a wireless access point (WAP). Which model router is it?
Google is your friend
Old 08-04-10, 10:04 AM   #4
454697819
can be done... just not with my expensive net gear...
pos
Old 08-04-10, 10:41 AM   #5
flymo
flymo's Avatar
Not really Stu unless its a feature of the router. You can buy wifi network range extenders to do this though.
Also, you can buy a wifi adapter that you can connect the Xbox to.
Old 08-04-10, 10:42 AM   #6
pookie
pookie's Avatar
I did this with an old homehub I picked up for peanuts on ebay
http://www.jarviser.co.uk/jarviser/repeaterhubs.html
I worked with my billion adsl modem. Otherwise have a look at using powerline comtrend plugs for connecting up using the mains network in your house as an alternative
Old 08-04-10, 10:48 AM   #7
flymo
flymo's Avatar
Originally Posted by pookie View Post
...Otherwise have a look at using powerline comtrend plugs for connecting up using the mains network in your house as an alternative
good idea, I use these to connect up my Slingbox at the other end of the house
Old 08-04-10, 11:28 AM   #8
plowsie
Like I say, I have a few routers kicking around at home, so was just being tight I suppose. Those Comtrend powerline plugs look a good idea.
Old 08-04-10, 12:09 PM   #9
gettin2dizzy
A lot of routers have this function as standard, and a lot of routers you can hack easily.
I use my laptop's wireless connection to connect my xbox to live... wirelessly
Microsoft can get fudged if they think I'll pay £60 for a wireless card.
Old 08-04-10, 12:17 PM   #10
hindle8907
hindle8907's Avatar
yeah i think some of the belkin range offer this feature and you bridge the connections i have never done this but im sure it can be done.
broadband router kwak zzr Idle Banter 22 17-11-08 08:18 PM
what router? kwak zzr Idle Banter 39 14-11-07 05:21 PM
Sky Router & VOIP 600+ Idle Banter 8 01-05-07 06:32 PM
Router and DSL Needed?? Demonz Idle Banter 1 14-12-06 05:29 PM
DSL router dead. rictus01 Idle Banter 8 12-12-06 03:43 AM
