Old 10-04-10, 09:31 PM   #1
ricky
Default How much weight do you have fitted to each wheel?
well after balancing my wheels and tyres i got thinking of how many other people have loads of weight fitted
mine when i started had 80g on the front and 90 on the back.
it now has a hell of a lot less than that lol
So how much is fitted to yours?
Old 10-04-10, 09:51 PM   #2
TSM
The Sick Man
TSM's Avatar
Default Re: how much weight do you have fitted to each wheel!!!!!!!!
does it matter as long as the wheel is balanced?
Old 10-04-10, 10:53 PM   #3
Red Herring
Red Herring's Avatar
Yes if you're buying the weights!
I put my wheels on the balancer without any tyres on them and marked the heavy point. Then when I fit the tyres I make sure I match heavy point to light point on tyre (Dunlops for example are marked with a yellow dot) and that way quite often I don't have to add any weight at all, or at least very little.
Old 10-04-10, 11:36 PM   #4
ricky
very true my tyres had a red dot, but i didnt have a balancer at the time so put the dot on the valve, the front only needed 10g weight 5 on each side to get it 100% lol
with buying weights im tight i reused mine just added fresh double side trim tape i had in garage
Pointy Front and Rear wheel weight? Ward_650 Bikes - Talk & Issues 2 13-02-10 01:59 PM
Weight of an SV front wheel? NielSV650 SV Talk, Tuning & Tweaking 4 09-02-10 01:19 PM
Wheel weight Holdup Bikes - Talk & Issues 7 11-05-09 03:15 PM
getting tyres fitted to a loose wheel in se kent ricky SELKENT 8 27-11-08 03:18 PM
Wheel Weight Glue fizzwheel SV Talk, Tuning & Tweaking 2 15-06-05 12:22 PM
