anybody any advice / experience regarding these on a curvy?how do you go about getting the correct amount of tension?
![]() h. |
dont know but i think its just a locknut thingy. why not just swap for k3 tensioners, it would be a royal pain in the rse getting in to adust manual ones every time it needed doing...
I know how they work but its getting the tension at the correct level setting i'm wondering about.
i have not tried one on the SV, but i had one on 1st gen cbr600 for almost 7 yrs, worked great, i never had to adjust it, though if i had to it was quite easy to do.
as for the correct tension, i was told you make it loose, then keep tightening till the cam-chain "chatter" stops, then you go 1/4 turn more and lock it. not sure how exact this approach is, but as i said, 7 yrs/40K (km) without ever having to think about it... so i guess it is close enough ![]() |
just checked and re shimed a couple of valves on my curvy which involves the cam chain tensioners. Are you asking about the original ccts? these dont need setting.
Cam Chain Tensioners | sv_rory | Stuff Wanted | 4 | 08-10-09 09:58 AM |
Chain tensioners | Stingo | Stuff Wanted | 0 | 16-08-07 08:22 PM |
cam chain tensioners | Duck-man | SV Talk, Tuning & Tweaking | 3 | 08-09-06 06:27 PM |
Cam chain tensioners | northwind | SV Talk, Tuning & Tweaking | 16 | 05-01-05 06:33 PM |
Cam Chain tensioners on a K3.. anyone?? | valleyboy | SV Talk, Tuning & Tweaking | 7 | 26-12-04 12:55 PM |
