Old 23-04-10, 02:08 PM   #1
Milky Bar Kid
Default Scorpion End Can (Complete Novice Alert!)
Ok, so I have purchased Mikelcfc's Scorpion can he was selling on here. He has sent me the can, link pipe and bracket but me being a complete numpty when it comes to these things, has no idea where to start with fitting it.
Can someone maybe give me step by step...BASIC, and I mean basic, instructions?
My bike is a K1 btw...
Old 23-04-10, 02:09 PM   #2
Default Re: Scorpion End Can (Complete Novice Alert!)
Have you got something to cut the pipe with? A grinder or hacksaw?
Old 23-04-10, 02:10 PM   #3
Milky Bar Kid
I'm sure there are several hacksaws in the shed.....
Old 23-04-10, 02:12 PM   #4
Get a decent blade and cut your silencer off, usual spot is 50mm from the weld IIRC.
Old 23-04-10, 02:14 PM   #5
Milky Bar Kid
Oh...cutting things off....sounds a bit scary!
Old 23-04-10, 02:15 PM   #6
Can always weld it back on if you get it wrong
Old 23-04-10, 02:40 PM   #7
husky03
if your struggling you can head up here when it suits you and i'll fit it for you mrs
Old 23-04-10, 02:46 PM   #8
Drew Carey
Not Fizzwheel
Drew Carey's Avatar
Dead simple. Like Mr YC said, get yourself a fresh hacksaw blade. Then measure 50mm from the exhaust weld back towards the current can. I would recommend if you can putting some masking tape on and draw on that, as stops the blade jumping around.
Then when sawing it WILL take ages.....but be patient. Once you get bout a third the way through it becomes easy.
Then simply slide can onto link pipe, slide it on and secure on cut end with a clamp (can't remember what they are now!!!! Doh). Then attach can with strap.
"Feckinnnn Unluckkeeeeeeee"
Old 23-04-10, 03:19 PM   #9
Biker Biggles
Biker Biggles's Avatar
Or buy a cheap angle grinder to cut it-----So much less like hard work.
Old 23-04-10, 04:36 PM   #10
Milky Bar Kid
Its on! A friend came round and we got a loan of an angle grinder and fitted it. Sounds amazing. No baffle in it though so hope MOT goes ok....
Novice Day Sideshow#36 Mini-Twins 7 21-02-08 05:32 PM
scorpion oval can or the scorpion street extreme jans1971 Bikes - Talk & Issues 6 03-02-08 10:41 PM
Novice track day Airfix The Border Patrol 7 27-01-08 10:02 PM
novice track day jim@55 SV Ecosse 8 25-05-07 07:31 AM
Hello.... from the novice! pljharvey The Essex Lounge 15 19-05-05 09:39 PM
