Old 24-04-10, 07:53 PM   #1
Swin
Swin's Avatar
Default No fuel pump noise when switching on ignition
Hi,
I've done a search on the forums and wonder if there are any more things I can try to rectify this problem.
When I turn the ignition key, all the regular lights and such show up, I don't hear the fuel pump pressurising and have FI showing on the display.
If I turn the key on and off it will eventually start to work. I searched for solutions and will try giving the ignition key slot a squirt with WD, as was advised in a previous post.
is there anything else that could be worth a go before I take it in to the shop? I have only just got back from an extra week stranded in Tenerife courtesy of that Icelandic volcano, so would appreciate any money saving tips that could be given!
Swin is offline   Reply With Quote
Old 24-04-10, 07:56 PM   #2
barwel1992
Default Re: No fuel pump noise when switching on ignition
kill switch on bars ? common mistake
Old 24-04-10, 07:59 PM   #3
Swin
Swin's Avatar
The kill switch was in the on position, but I did try flicking it on and off a couple of times in case it wasn't made - perhaps that could do with a squirt too !
Old 24-04-10, 08:01 PM   #4
barwel1992
in gear ?
just throwing things out there
low battery? (not enough power to power the pump)
Old 24-04-10, 09:06 PM   #5
davepreston
check the usual cluprits sidestand switch, clutch safety switch
Old 24-04-10, 09:08 PM   #6
Holdup
Does the dash come up with "CHEC" (i think thats what it says) where the temperature should be when you switch on the ignition?
Old 25-04-10, 07:26 AM   #7
Swin
Swin's Avatar
I don't see it saying "chec" - I just have "FI" in the display, and the fuel warning light stays on, although it has a tank full of petrol.
Gave it a squirt of WD this morning into the ignition switch, it only took 3 off and ons before I was able to start, so I'm wondering if there may be a loose contact, but I'll try the switches that dp mentioned - thanks
Old 27-04-10, 08:47 PM   #8
Swin
Swin's Avatar
Update,
I gave the ignition barrel a good dousing with WD and the fuel pump hasn't failed to come on since
Nice cheap fix - lovely!
I post this as a lot of the posts I found when searching this problem didn't have any follow-ups, hope this helps someone else!
fuel pump continous hissing noise faztbikez SV Talk, Tuning & Tweaking 7 06-05-10 09:20 PM
Fuel pump trouble pillphil SV Talk, Tuning & Tweaking 2 23-10-09 02:24 PM
How do i remove the fuel pump on a K5 tonny006 SV Talk, Tuning & Tweaking 10 01-10-08 08:45 PM
Fuel pump cornishrider SV Talk, Tuning & Tweaking 6 02-03-08 07:25 PM
K5> fuel pump phil24_7 Stuff Wanted 11 29-10-07 05:18 AM
