Old 27-04-10, 10:15 AM   #1
sloppy joe
Default Reg/Rec killed my battery?
More battery woes, guess its that time of year. ('99 naked by the way).
Posted recently ref possible leakage (6 month old battery going flat every couple of days). However, 0.5ma leakage seemed OK after forum help (despite Haynes manual saying 0.1ma max).
Tested charge rate -
(@5000 rpm).
No lights - 14.5v
Lights on main - 12.8v
This appeared low with lights (was lower after a ride, but can't remember figures now), so decided reg/rec duff. Went for 20 mile ride no lights to see what happens (and it was a lovely afternoon). Battery not strong enought to turn engine next day. Charged up for 6 hours with optimate (didn't have time to leave for full charge/test cycle).
Away for a week, just ordered new reg/rec. Plugged in optimate - won't charge. Utterly dead and apparently irrecoverable.
Now I am thinking poss not reg/reg, or has reg/rec knacked the battery? Or just coincidence? Or is the eakage in fact too high?Battery only bought in Oct last year, and apart from the really crappy few weeks of weather, used mostly daily for 9 mile each way commute, plus weekend rides.
Cheers if you got through the essay above, cheers even more if you can give any words of wisdom.
Old 27-04-10, 10:42 AM   #2
jonny.boyd
jonny.boyd's Avatar
Default Re: Reg/Rec killed my battery?
I had the same problem, battery going flat every couple of days. Turned out Reg/Rec was faulty and was charging properly with no lights, but soon as lights were on the charge dropped low enough that it was actually the draining the battery rather than charging it!
I've been told it is very possible that a faulty reg / rec can easily knacker a battery (charge goes above 14.5V and is actually overcharging the battery which kills it). In your case it could be possible that the battery has been drained (below 12V or something) so much that it just can't recover anymore.
I'd get new reg / rec and new battery. Fingers crossed problem sorted
jonny.boyd is offline   Reply With Quote
Old 27-04-10, 11:23 AM   #3
(@5000 rpm).
No lights - 14.5v
reg rec can kill battery by deep cycling them.
check wiring too as you can lose those volts through scabby connectors especially when drawing the higher current of the lights.
Old 27-04-10, 11:37 AM   #4
sloppy joe
Connectors all appear OK, despite bike living outside under a cover, and I regularly dose up with WD40. Think maybe another half ton for a battery will be following the half ton shelled on a reg/reg.....
Old 27-04-10, 11:38 AM   #5
I like the more modern type of reg-rec and direct wiring to the battery.
Old 27-04-10, 11:41 AM   #6
sloppy joe
Removal of bodywork and replacing reg/rec well within my spannering skills. Modifying parts/wiring moving out of my comfort zone.
Old 27-04-10, 11:42 AM   #7
Is "The Fax" Halifax?
Old 27-04-10, 11:47 AM   #8
sloppy joe
Yep, Saville Park area. Actually, think I bumped into you at Halifax Motorcycles few months back when I was having hideous misfire issues (now mysteriously cleared up, although Pro-FST seemed to help in the really cold weather, as did letting the bike catch on the choke on starting, rather then messing with throttle too).
Old 27-04-10, 11:49 AM   #9
Aha, howdy
Changing reg rec is easy anyway if you fancy giving it a go, otherwise a replacement stock one is easier to fit though slightly less reliable.
Old 27-04-10, 11:54 AM   #10
sloppy joe
Stock one already on its way (hopefully). Now to search for reasonable priced battery that won't give up too quickly. I can just about stomach forking for a battery every 18 months or so, but after 6 months I am muttering. Although if it was the reg/rec that stuffed it, I guess I can't blame the battery.
I've Killed Another One squirrel_hunter SV Talk, Tuning & Tweaking 70 02-09-09 04:15 PM
Optimate battery charger drains the battery flymo Bikes - Talk & Issues 10 10-06-09 10:41 AM
Killed my car - can anyone help? krhall Idle Banter 83 29-08-08 01:56 PM
I killed my baby :-( philbut Thames Valley 19 08-04-08 06:08 AM
Battery/Starting problem - new battery hasnt fixed it! Aaron SV Talk, Tuning & Tweaking 13 24-01-05 05:21 PM
