Old 28-04-10, 03:51 PM   #1
barwel1992
Default SV650 fork length ?
what are the sv fork length and what are the shortest forks i should use on the sv ?
cheers
EDIT OHH cr*p spelt length wrong in the title
Old 28-04-10, 05:29 PM   #2
barwel1992
Default Re: SV650 fork length ?
any one, cant seem to find a definitive answer
Old 28-04-10, 05:44 PM   #3
simesb
That's because there isn't one.
Old 28-04-10, 06:10 PM   #4
barwel1992
lol i didn't mean that about the shortest forks on the sv question just the first one about the stock forks
Old 28-04-10, 06:41 PM   #5
simesb
Why don't you measure yours?
Old 28-04-10, 06:47 PM   #6
Jayneflakes
Jayneflakes's Avatar
What length do you need?
I could go and measure mine up if you like, although it might take me a few mins cos I may have to hug my bike again!
The Haynes manual lists them as 41mm forks with 130mm travel.
Jayne you're a Pussy Magnet
Old 28-04-10, 06:56 PM   #7
barwel1992
i need from centre of the axle to the top of the forks, but not counting the adjusters and abviousy add on what ever sag you have ( )
if you could do that it would be brill
and simesb my bike is 180 od miles away in Devon smashed up on some blokes drive lol
Old 28-04-10, 07:12 PM   #8
Jayneflakes
Top of stanchion to centre of the wheel axle was 750mm, however it may be more due to not knowing exactly how much static sag I have.
Hope that this is of some help.
Good luck with the rebuild.
Old 28-04-10, 07:14 PM   #9
barwel1992
cheers (once again)
Old 29-04-10, 09:45 AM   #10
Kuku
Barwel, I measure mine too - 745mm. from the centre of the axle to the top of the tube, without adjuster and cap-nut
k5 fork spacer length? fast-lad SV Talk, Tuning & Tweaking 1 02-06-09 04:42 PM
sv650 k1/2-k3/6 fork spacers fast-lad SV Talk, Tuning & Tweaking 2 25-09-08 04:11 PM
SV650 K3 fork replacement nicollow SV Talk, Tuning & Tweaking 10 05-08-06 05:31 PM
Front fork tubes - length? figer SV Talk, Tuning & Tweaking 0 18-06-06 10:53 AM
SV650 Fork Caps Mike1234 SV Talk, Tuning & Tweaking 2 13-12-04 08:19 PM
