Old 29-04-10, 03:10 PM   #1
sniff
sniff's Avatar
Default Few bits for a Bandit or SV650
Got further items Ive recovered from my shed. ALL PRICES ARE WITH THE P&P SO NO OTHER COSTS TO ADD.
One clutch cable £8 inc P&P
One throttle cable £12inc P&P
Pair of fork dust seals £10 inc P&P Pyramid make
Pair of cheap indicators not used £5 inc P&P
Bandit stainless engine bolt kit £10 inc P&P
Front wheel oil seal £4 inc P&P
Genuine Suzuki fork seals £15 inc P&P
Genuine Rear wheel dust seal £10 inc P&P
Just remembered Ive also got a nexxus exhaust for a Bandit. Just needs a clean up and I'll then get photos of this. £25 I'd prefer this to be collected due to size and weight.
Got a Beton gas shock for a Mk1 Bandit 600 £90 inc P&P
If you want photos of anything let me know and I'll email these over.
sniff is offline   Reply With Quote
Old 04-05-10, 10:12 AM   #2
sniff
sniff's Avatar
Default Re: Few bits for a Bandit or SV650
Cant belieave no one wants any of this stuff!!! Most I think will fit the SV won't it?????
Old 04-05-10, 11:43 AM   #3
Elltg
Any chance of a picture of the front wheel oil seal? Had my wheel off recently and noticed the bearing on one side did not have a side cover and the grease was exposed, I'm guessing it is okay because of the job of the oil seal? Just want to make sure I didn't just lose the damn thing instead.
Old 04-05-10, 01:13 PM   #4
kas
Have you got any pics of the indicators? Are they standard ones or aftermarket?
Old 04-05-10, 02:06 PM   #5
sniff
sniff's Avatar
Sorry for delay. There is a small 1 cm crack on one of the lenses only noticed this once i photographed them. Cant be seen from a distance.
Wheel dust seal to come in a few moments.
Old 04-05-10, 02:16 PM   #6
sniff
sniff's Avatar
And front wheel seal.
Old 11-05-10, 12:58 PM   #7
sniff
sniff's Avatar
*******Cough*******
Does no one need anything here???????
Old 12-05-10, 12:22 PM   #8
Haggis Supper
Could do with a longer clutch cable for my K6s as I want to change my handle bars to the naked ones, so don't know if what you've got would do the job though??
Old 12-05-10, 05:22 PM   #9
sniff
sniff's Avatar
As its a bandit clutch cable its longer than the SV one. I put renthals on my B6 and was just long enough. So this should be perfect.
Old 12-05-10, 06:27 PM   #10
sniff
Will the fork seals work with the curvy units?
Regards
Andy
SV650 Vs Bandit 600. andrew311 SV Talk, Tuning & Tweaking 42 09-09-09 12:40 PM
Suzuki Bandit 600 Bits & Bats (98) vardypeeps For Sale - Other Bikes and General biking items 3 24-05-09 05:04 PM
Some Bandit bits Swin For Sale - Other Bikes and General biking items 4 14-03-09 07:42 PM
Need bits lots of bits sv650 2002 curvy K1 Nicky S Stuff Wanted 27 13-03-09 02:22 PM
SV650 after a Bandit 650 ccurts SV Talk, Tuning & Tweaking 13 16-04-07 08:56 PM
