Old 02-05-10, 05:08 PM   #1
barwel1992
Default SV front master cylinder - OK with 4 piston calipers?
will the standard SV front master cylinder be able to power the 4 pot gold brembo's off the rsv mille front end (2000 front end, same brakes as 2002-2005 tuono non r model)
look the same as these
or is it worth getting a brembo one to match any way ?
thanks
Old 02-05-10, 05:53 PM   #2
Default Re: master cylinder
Yeah it will work.
Brembo is great if you can afford.
Old 02-05-10, 06:20 PM   #3
barwel1992
just looked at them £269 for a master cylinder
YC is there any M/C's that are cheep and worth upgrading to ?
Old 02-05-10, 06:22 PM   #4
I keep meaning to try RC51 one. Also radial one from late GSXR might be worth a try, or one from late R6.
TBH see whether you need it with those caliper. With tokico 4 pots of SRAD I run out of balls before I run out of brakes.
Old 02-05-10, 06:35 PM   #5
barwel1992
lol :P there not radial though they are standard mount or wont that matter ?
Old 02-05-10, 06:38 PM   #6
Calipers do not care which direction master cylinder is pointing, neither does master cylinder care which way caliper bolts are pointing.
All you are interested in is area of pistons. Ratio of piston area gives you ratio of force.
For example size of pistons in SRAD works well with 5/8" MC
Old 02-05-10, 07:01 PM   #7
barwel1992
ahh ok now i get it, just kept seeing radial master c advertised and thought there might be something more to it
well if thats the case, is there away to find out the correct MC for the piston area.
Old 02-05-10, 07:06 PM   #8
Extreme cases;
Too small = Not enough swept volume to bring pads into hard contact with discs = no brakes
Too big = not enough pressure advantage to stop you
Cases you care about:
14mm MC, lots of movement in the lever, LOADS of advantage though so not much force required.
15.87mm MC (5/8" = stock), Mix of firm lever and power.
bigger ones, 17mm or 19mm like RC51, firmer lever, less mechanical advantage but feels rock solid and lots of people like this feel.
Brembo do you whatever, you can get different bores and strokes (stroke gives you idea of initial mechanical advantage in lever) you can even get RCS where you can adjust mechanical leverage while you ride
So long as brakes work there is no right/wrong just different feel. IMO use your stock MC to check they work and think about changing later.
Old 02-05-10, 07:16 PM   #9
barwel1992
ok cheers for that will give the sv one ago then, if its no good will look at upgrading
Old 02-05-10, 07:45 PM   #10
A cautionary tale:
http://www.peterverdonedesigns.com/1000RRmaster.htm
Front master cylinder sniff Stuff Wanted 3 28-04-10 09:19 AM
Radial Front Master Cylinder. petevtwin650 SV Talk, Tuning & Tweaking 5 17-11-07 12:16 AM
Front master cylinder taggy Stuff Wanted 7 31-08-07 06:02 PM
R1/R6 Front master Cylinder jonnygman SV Talk, Tuning & Tweaking 6 29-04-07 01:10 PM
front master cylinder upgrade andygib SV Talk, Tuning & Tweaking 4 16-08-06 07:49 PM
