Old 12-05-10, 09:21 AM   #1
Kate Moss
Default IT Help
Can you edit a scanned document? If so, how do you do it! I can cut and paste the text i need onto a word document bu cant seem to edit the text.
Any ideas?
Old 12-05-10, 09:22 AM   #2
suzsv650
Default Re: IT Help
What about this?
Old 12-05-10, 09:23 AM   #3
Tara
Default Re: IT Help
without being there i can't think properly but i don't think you can edit it unless you have adobe writer/editor
Old 12-05-10, 10:28 AM   #4
Bri w
Bri w's Avatar
Default Re: IT Help
wot Tara sez
Old 12-05-10, 10:42 AM   #5
phi-dan
phi-dan's Avatar
Default Re: IT Help
Depends on how you scan it and if you have the original or not. If it's scanned to a PDF file, then you will have the devil's own job as conversion back to Word frequently borks the formatting. If you have the original then you could scan it to an OCR package (some will even import and OCR from a PDF / JPG / etc) which then outputs to Word anyway. Omnipage is pretty good (other software titles are available, standard rates apply, calls from mobiles will cost an arm and a leg)
Was: Red curvy S: crash bungs, double bubble screen, fenda extenda, HEL front lines, OEM belly pan
Now: Blue FZ6 Fazer
phi-dan is offline   Reply With Quote
Old 12-05-10, 11:15 AM   #6
ophic
ophic's Avatar
Default Re: IT Help
Just to clarify, the reason you can't edit a scanned document directly is because it's an image - effectively a photograph taken of the document. It doesn't contain text information like a Word document does. You use OCR (optical character recognition) packages to convert an image into a document - it optically recognises each character and creates the corresponding text information. However my experience of these is that they don't work all that brilliantly. YMMV.
Silver SV650SK3, Fuel exhaust
Old 12-05-10, 11:35 AM   #7
slark01
Default Re: IT Help
Scan document, Now open with PAINT, erase word(s), write what you want in it's place. Job done.
Did this on a scanned Bank account summary for my Bro. Then emailed it to him in Thailand, just so it looked liked he had loads of money in his account.
Ste.
Old 12-05-10, 11:39 AM   #8
Viney
Default Re: IT Help
Scanned docs...
PDF - You need a PDF editor and not all will work, i recomend Foxit (evaluation copies can be found)
Tiff - No
Gif - No
JPEG - No
Old 12-05-10, 11:50 AM   #9
ophic
ophic's Avatar
Default Re: IT Help
a PDF from a scan is usually just an image encapsulated in a PDF - ie no OCR has taken place. So this step still needs doing, even if you have a PDF editor.
