Old 18-05-10, 09:44 PM   #1
BBadger
Default How to clean brake pistons?
Evening all
I was wondering if anyone could be so kind as to tell me the best way to cleaning a piston as i know very little about breaks.
I just popped the rear ones out on the vfr and they are fine at the bottom but the top 10/15mm is abit discoloured and has what looks like rust spots ( or is it really old dirt???)
Is there a preferred way to clean without damaging them or are they buggered ?
ill grab some pics tomorrow to help the diagnosis
[Edit] Also the half of the dust seal looks in a very bad way all torn up like its been hacked at.
Thanks
Brock.
Old 18-05-10, 11:43 PM   #2
Default Re: Brake pistons
That green scouring pad. If that doesn't work, finest wet and dry you've got with some WD or better yet silicon spray on it.
Old 18-05-10, 11:58 PM   #3
barwel1992
i used extra fine wire wool on mine with wd40
Old 19-05-10, 12:14 AM   #4
timwilky
timwilky's Avatar
always clean round the pistons and never along the length. that way you are not leaving minute scratches that permit seal leaks.
I have a rubber bung with a bolt through it and washers either side. put the bung in the piston and tighten the nut and compress it. This expands the bung to grip the piston. put it in a secured drill (held in vice) and give it a spin. a scouring pad with a bit of t cut soon gives it a clean.
Not Grumpy, opinionated.
Old 19-05-10, 08:13 AM   #5
mjc
cunning.
Old 19-05-10, 08:16 AM   #6
1200 wet and dry with the wd method! after you've given them a soak in wurth brake cleaner!
Old 19-05-10, 08:19 AM   #7
BBadger
Will give it ago later today and report back!
They have been sitting in brake fluid all night and were filthy when i got them out so hopefully they will be ok by now and clean as a whistle with some W&D
Old 19-05-10, 08:41 AM   #8
I'm_a_Newbie
Default Re: How to clean brake pistons?
Never use wet and dry paper on brake pistons, it leaves small particles imbedded in the metal surface that can degrade the seal over time. Always use fine wire wool or green kitchen scourer. If you use anything like WD40 make sure you get rid of all traces of it before re-assembly. It only takes a few hours for any mineral oil to destroy a brake seal. Always lubricate the piston and seal with either brake fluid or rubber grease.
Tim
Old 19-05-10, 11:50 AM   #9
another thing thats worthwile is flushing the caliper with brake fluid as it guarantees that there is no crap in the calipers, and wash ur pistons in brake fulid.
Ditch the fluid as contaminated
Best way to clean up brake pistons? curium SV Talk, Tuning & Tweaking 12 06-04-09 09:42 PM
Brake Pistons? vardypeeps SV Talk, Tuning & Tweaking 4 29-08-08 12:12 PM
scaring on brake pistons huge SV Talk, Tuning & Tweaking 2 13-01-06 04:32 PM
new brake pistons and seals. where from? raymond smith SV Talk, Tuning & Tweaking 2 30-04-05 09:24 PM
Rear Brake Pistons JMCHITTOCK SV Talk, Tuning & Tweaking 8 22-02-05 09:23 AM
