Old 20-05-10, 08:55 PM   #1
kcowgergmm
Default engine out what else
so i had to take the engine out of my sv to get to the spacer that the rear engine bolt that goes all the way through the motor screws into. the bolt snapped on me when i was checking the torque with a calibrated torque wrench to correct ft lbs. corrosion is what caused it but in order to take everything apart i ended up dropping the engine so since i already got it out is there anything i should do to it while its out since its not that fun to un-hook 40k things
Engine ... yes an engine Vindaloo Stuff Wanted 10 12-11-09 08:09 PM
Engine Breaking? Hopefully not. Engine braking - is that OK? butterick99 SV Talk, Tuning & Tweaking 14 12-09-09 10:31 PM
Dead Sv Engine or Engine block.... Andy Jeffries Stuff Wanted 6 15-08-09 07:46 PM
Engine braking... any hazzards engine wise? John 675 SV Talk, Tuning & Tweaking 21 28-03-08 07:20 PM
Which engine oil FG1 Bikes - Talk & Issues 13 04-12-06 06:56 PM
