Old 24-05-10, 05:51 PM   #1
kevin james
Default front tyre 120/60/17 or 120/70/17?
hi from a newbe
i have just swapped my fazer 600 for a 99 sv 650 naked,as soon as i rode the sv i had to have it brill bikes with great useable grunty power.
the front tyre needs replacing its a 120/60/17 i have been told that a 120/70/17 will be just as good and there seems to be alot more of the larger profile tyre to choose from,have any of you chaps used the larger profile and how did it differ from the smaller frofile.
thanks
kev james
Old 24-05-10, 06:23 PM   #2
Default Re: front tyre 120/60/17 or 120/70/17
i use a 60 and the difference is the turn-in rate with the 70 turning quicker.
U need to mod the front fender for it to clear the profile as the 60 is tight to the fender.
I like the 60 profile but the 70 is a supersport and super bike profile so if ur just doing weekend warrioring its better
Old 24-05-10, 06:31 PM   #3
With avon storm I prefer the 70 but it is small change. Not noticeable really if you are going from a different tyre anyway.
Numbers on side only vaguely resemble the size of the tyre anyway.
As far as I know plenty minitwin guys using 120/70 on stock fender.
Old 24-05-10, 10:53 PM   #4
Kat1986
I swapped to the 70 profile when I put a gixer front end on my bike and I have noticed that it tips into corners much faster Although this might be partly due to having different forks on the bike.
As well as making the bike handle a bit sharper, it might be a good idea if you do lots of fast riding as you'll have a larger area of the tyre in contact with the road at high lean angles.
Old 24-05-10, 10:55 PM   #5
SRAD forks are about an inch short, which helps too
Old 25-05-10, 08:10 AM   #6
the other option is to get a 110 tire is tad more expensive but has the same effect.
If your a speed nut it'll reduce stability also
Old 25-05-10, 11:50 AM   #7
I think I'll leave that one to you, thanks.
Old 25-05-10, 07:25 PM   #8
TOLAROS
Default Re: front tyre 120/60/17 or 120/70/17?
70.Much better
Old 25-05-10, 08:49 PM   #9
Rob969
I had a 110/70 fitted when i got the bike have just changed it back to standard 120/60 and can't really notice a great difference.
Old 25-05-10, 09:44 PM   #10
My mates done it on a bandit and prefers it. The turn in pace suits his riding style
110/70 front tyre Rob969 SV Talk, Tuning & Tweaking 4 17-01-10 04:08 PM
GSXR front end swap - front tyre profile. Khewett SV Talk, Tuning & Tweaking 12 11-05-06 11:24 AM
Front tyre and can you mix front and back makes? creamerybutter Tyres 9 12-05-05 08:38 PM
120/60 or 120/70 Front tyre Lennie SV Talk, Tuning & Tweaking 2 05-01-70 11:01 AM
Front tyre and can you mix front and back makes? stick Bikes - Talk & Issues 4 04-01-70 03:19 PM
