Old 28-05-10, 08:02 PM   #1
Tony Herbert
Default Cant get neutral when bike is warm
Clutch drags only when bike is warm. Cant get neutral when engin is running. No problem when engin is stoped. Any ideas?
Old 28-05-10, 09:24 PM   #2
beabert
Default Re: Cant get neutral when bike is warm
Common problem, you can try all the usual things first, like oil level and clutch adjustment but from my experience only changing the friction plates to ebc ck3377 ones totally got rid of it.
Three of us had the same problem recently, we all changed clutch plates to solve it.
Old 28-05-10, 09:54 PM   #3
ophic
ophic's Avatar
Too much oil can make neutral hard to find. Have you topped it up lately?
Silver SV650SK3, Fuel exhaust
Old 28-05-10, 10:00 PM   #4
rotax81
not too clued up on the SV but from the above replies i presume they are a hydraulic clutch.
warped plates, oil too thick, cable ajustment, worm ajustment are the only causes.
Old 28-05-10, 10:02 PM   #5
ophic
ophic's Avatar
650s are a cable clutch. 1000s are hydraulic.
Old 28-05-10, 10:08 PM   #6
rotax81
he doesnt mention what bike it is
if cable try tightening the cable a bit.
Old 29-05-10, 05:07 AM   #7
Tony Herbert
Really appreciate your comments. I have done all the usual. Changed the oil (twice!) got semi synthetic in now. Ive adjusted it every which way. I think I was hoping I wouldt have to change the clutch. Is it expensive? I presume its not too difficult. Do I need any special tools? I have changed clutches before but not on SV.
Thanks again
Tony
Old 29-05-10, 06:57 AM   #8
Take the front plastic cover off the frint sprocket and clear the built up crap from behind it, and make sure your chain is properly lubed and adjusted.
No need to do the drastic route until you have done all the basic checks, surprised no one has suggested the above to you.
I have this problem occasionally.....on both SVs, neither have had a clutch plate swap in their life!
Old 29-05-10, 02:27 PM   #9
Before doing anything else, adjust the clutch, not just the cable.
Like this:
Originally Posted by Me!
Slacken off cable adjusters at top and bottom, loosen lifter locknut, back out screw a bit, ensure that lifter arm is as far down as it will go, gently turn screw in until it contacts pushrod back out a bit, (~1/8th of a turn), then nip up the locknut, roughly adjust cable with lower adjuster - not too tight - then with top adjuster ensure that there remains a little slack all the way from lock to lock.
Replacing the clutch plates is a bit of a leap as a first try as a fix.
Old 30-05-10, 05:48 AM   #10
beabert
Thanks again
Tony
Make sure you rule everything else out first.
Most likely just the friction plates are needed but make sure the steel plates are flat, £40 of ebay, and £5 for black gasket maker from halfrds. No need to drop the oil, when on the sidestand the oil wont leak with the cover off.(curvy) Takes 20 minutes.
You need a torque wrench that measures as low as 5.5ftlb I guessed using a 10flb one lol.
The clutch can be very harsh straight after, needs a few miles to sort its self out. Its made an amazing difference to my bike.
Cannot get my bike into neutral. ihitge Bikes - Talk & Issues 9 01-05-08 03:41 PM
Staying warm on a bike wyrdness Bikes - Talk & Issues 47 12-12-07 08:02 PM
bike choking when revved hard and fast in neutral.... branny SV Talk, Tuning & Tweaking 11 05-09-05 08:14 AM
tyre warm up v's engine warm up? twotime SV Talk, Tuning & Tweaking 25 14-07-05 11:06 PM
Neutral Wiltshire7 SV Talk, Tuning & Tweaking 21 17-01-05 04:41 AM
