Old 31-05-10, 05:54 PM   #1
Default Maviczap's SV contracts deadly virus
Its been lying domant since that freezing cold rideout in March.
But now the virus has woken up.................. oh dear my SV has Seggoniteous
Out for a ride with my mates today, when I noticed
Symptoms................ my right hand front indicator fell off.
Luckiily I was able to ride home without doing any off roading or green laning........ but it was a close call
What can I do, is there any cure, our will all my bits start dropping off at random
Old 31-05-10, 06:16 PM   #2
Seggons
Default Re: Maviczap's SV contracts deadly virus
The symptoms are nothing to worry about. It's starts off with nothing more then a harmless bit of drooping... from the indicator. It then spreads to the nuts, as in numberplate nuts which slowly becomes loose over time. If you don't get it checked out by this stage it moves onto the front fairing with random bits coming adrift leaving you with bodywork that looks alot less desirable then it use to. If you reach this stage then it's too late for any possible cure. The next symptom is horrifying, read on if you must...
You have an encounter with some bush. So if any of the people here on the org has had any encounter with bush at any time within the last few months you may wish to go and see if there is any possible chance of survival.
So to round up, if you have any drooping, loose nuts, bodywork not looking as good as it used to or have encountered bush within the last few months your in big trouble I'm afried.
Old 31-05-10, 06:40 PM   #3
Yes thats EXACTLY HOW IT STARTED
Old 31-05-10, 07:29 PM   #4
OMG I'm not sure the bush will allow him in with all those symptoms!
Old 31-05-10, 08:25 PM   #5
kellyjo
MZ, you might also want to check around the 'drooping' area for insect occupants, Seggons had a nasty infestation (of the spider variety)
Old 31-05-10, 08:26 PM   #6
If it is its bleedy big as its eaten the indicator rubber grommet
Old 01-06-10, 06:46 AM   #7
BigBaddad
My winker droops when it's nowhere near a bush.
Old 01-06-10, 07:06 AM   #8
kellyjo
Drooping winkers are no good to my bush!!
Harmonisation of contracts :- advice please timwilky Idle Banter 12 08-03-10 02:56 PM
Deadly weather combo, Rain followed by freezing temps. no_akira Bikes - Talk & Issues 12 22-12-09 10:14 PM
Employment contracts Sudoxe Idle Banter 3 20-05-09 12:28 PM
Mobile Phone Contracts (Orange) TazDaz Idle Banter 7 09-09-08 09:23 PM
Carphone Warehouse - New Mobile Phone Contracts mattSV Idle Banter 0 17-07-08 08:04 PM
