Old 04-06-10, 09:02 AM   #1
Sruffy
Default Scottoiler Dispenser Nib Position
Hi
I installed a Scottoiler to my bike last week. However I went out last night to admire my handy work and just check that the chain was wet and the flow rate was correct and I noticed my dispenser nib was missing. Gutted.
I have seen that you can buy spare nibs online so have ordered two but what I want to know is has anyone else had this problem?
Is there a way of ensuring the nib is secured to the dispenser tubing securely?
Also where are people placing the dispenser nib? I had mine at the front of the sprocket at the 7 O'Clock position as recommended in the online instructions.
Any help would me much appreciated
Old 04-06-10, 09:41 AM   #2
Default Re: Scottoiler Dispenser Nib Position
as per instructions..
there is a tiny wee clip that comes with the kit I think to tighten the nib on .. not sure
one thing.. do you back the bike out of the garage?? or at any time back it up.. this bends the nib the wrong way often and it can flick back and ping off when u set off
Old 04-06-10, 09:42 AM   #3
i still got me box of spare bits I have a look in a tic
when I am out of bed !
Old 04-06-10, 09:54 AM   #4
punyXpress
punyXpress's Avatar
The ' nibs ' are just short lengths of the black vacuum pipe, so buy a length of that & make your own.
The business end should be tapered & heat the other end over a match or lighter to form a blob - this will hold it in place.
As Quiff says: beware of putting pressure the wrong way when reversing the bike. This can also get muck up the orifice, and you don't want that!
Now: Street Triple R
Old 04-06-10, 10:08 AM   #5
You need to get it in the right spot so it doesn't get ripped off when backing up.
Old 04-06-10, 11:34 AM   #6
could a bit of heat shrink hold it on>?
mind you mine has never come off.. its all about putting it in the right place.. as there are times when backing up your bike cannot be avoided
Old 04-06-10, 11:35 AM   #7
Yeah you can't have it so it gets ripped off every time you let it roll back 6"!
Personally I just chucked it and used a bit of brass tube.
Old 04-06-10, 12:19 PM   #8
Sruffy
Thanks for the info guys. Sounds like backing up the bike may have caused it to come loose.
Can someone suggest a good position for the nib as unfortunately not backing up my bike isn't an option
Old 04-06-10, 12:59 PM   #9
Not dragging on the sprocket.
Old 04-06-10, 02:00 PM   #10
punyXpress
punyXpress's Avatar
Just have a look on the Scottoiler website - there's a bucket load of info there.
Scottoiler Dispenser Nib jamesterror Bikes - Talk & Issues 15 09-07-09 03:43 PM
new position? hovis Idle Banter 6 02-11-06 10:42 PM
Scottoiler: Dispenser Assembly & Injector. Akula Idle Banter 2 06-05-06 08:23 AM
Anyone else in my position? lukemillar Bikes - Talk & Issues 12 05-04-06 05:31 AM
Scottoiler - getting it to stay in position rob13 Bikes - Talk & Issues 15 09-03-06 11:06 AM
