Old 08-06-10, 10:32 AM   #1
pwk
Default Oiling the chain with used engine oil
Ok guys theres quite a bit about this on various other threads but no really straight answer. Is there any reason why used engine shouldnt be used to lube the chain instead of other specialist chain lubes?
Old 08-06-10, 10:36 AM   #2
mister c
mister c's Avatar
Default Re: Oiling the chain with used engine oil
No.
The only difference with old engine oil & chain oil is that chain oil has an anti fling agent in it & it tends to stay on the chain for longer.
I use old engine oil & have done for about 12 -18 months. It does need to be done regularly if you use it in wet weather. I do mine once a week at least.
Old 08-06-10, 11:07 AM   #3
jambo
jambo's Avatar
People will come along and disagree with me but the simple answer is I use it for the entire life of my chains.
Up until you dropped it out of the engine it was apparently good to lubricate pistions and valves at 14,000rpm (ok, 10,000 on an SV). I fail to believe that the act of removing it from the engine stops it being an effective lubricant
Jambo
Old 08-06-10, 11:09 AM   #4
danf1234
A lot of scottoiler users swear by it in their oilers.
Old 08-06-10, 11:10 AM   #5
simesb
I use goose fat as that is a lubricant too
Old 08-06-10, 11:10 AM   #6
ophic
ophic's Avatar
No.
Less fling means less to clean off the bike. But it's also really hard to clean off cos it's sticky. You can't win
Silver SV650SK3, Fuel exhaust
Old 08-06-10, 11:12 AM   #7
boot
Jambo
+1
Old 08-06-10, 12:03 PM   #8
johnnyrod
johnnyrod's Avatar
Engine oil is a great lubricant but inside the engine there's a constant supply of it, like a Scottoiler. Unless you have that, it'll fling off quickly and be gone. Engine oil is made to pump easily, chain lube is made to cling like a limpet.
Old 08-06-10, 12:59 PM   #9
sam anon
I don't doubt its lubrication qualities, but use dedicated chain lube to avoid fling.
With regard to cleaning what does come off, Mr Sheen works wonders.
Old 08-06-10, 01:02 PM   #10
Lozzo
Buy a Scottoiler and fill it with cheap chainsaw oil. Simples
Chain Oiling G SV Talk, Tuning & Tweaking 24 14-05-07 01:09 PM
Chain Oiling krhall Bikes - Talk & Issues 35 11-12-06 02:49 PM
oiling chain hovis Bikes - Talk & Issues 22 22-10-06 09:47 PM
Warning - You can use engine oil on your chain. Tony_BLY SV Talk, Tuning & Tweaking 43 10-02-06 12:10 PM
Oiling my chain rpwoodman SV Talk, Tuning & Tweaking 28 27-01-06 02:28 AM
