Old 14-06-10, 01:48 PM   #1
cringer
Default sv650 what mpg and what do you get to a tank?
What do u guys get to a tank (when the orange light comes on) and what mpg are you getting out of your sv650's?
Mcn states 40mpg but it must be higher than that, i used to get 46mpg out of my blade!
Im only on my first tank of fuel so will update figures when i next fill up.
Btw. The way i work out mpg is thus:
when filling up to the brim make a note of the litres you put in.
Divide the litres you put in by 4.55 to give the uk gallon amount
Then divide the gallons by the miles you clocked up since you last filled up. Obviously it helps if u reset your trip counter when you fill up.
That is my own formula btw so if anyone has a better more accurate method then please share.
Old 14-06-10, 02:01 PM   #2
ThEGr33k
Default Re: sv650 what mpg and what do you get to a tank
I used to get between 50-75mpg. Depending on the riding obviously. HTH
Oh and welcome to the forums, fellow Yorkshire man, or you just moved here?
Old 14-06-10, 02:25 PM   #3
ophic
ophic's Avatar
I use fuelly.com
Silver SV650SK3, Fuel exhaust
Old 14-06-10, 02:26 PM   #4
Gnome
About 120 miles to a tank.
Old 14-06-10, 02:28 PM   #5
mcgrimes
its worth while noting that mcn probably use an american gallon which is a lower unit measurement than ours!
Old 14-06-10, 02:40 PM   #6
kellyjo
Between 95 and 130 miles to tank (13.5 litres to light coming on). Depends how i'm riding
Old 14-06-10, 03:20 PM   #7
BBadger
Roughly 45-50mpg i think
120-130 before light and i dont bother filling up till about 150 odd.
Old 14-06-10, 03:55 PM   #8
trumpet
Gladius can do 45 miles after yellow light 30 flashing. 200 miles top=up if I know where the petril station is 195 miles to coldstreak 13.55 ltrs.
Old 14-06-10, 03:59 PM   #9
Nelson
I did 56 out of the last tank - 190 odd miles, and 61 out of the tank before that - 203 miles. Both times I filled it up, I could hardly squeeze 16 litres in...
Old 14-06-10, 05:29 PM   #10
Ian P
Ian P's Avatar
I get abot 150 miles on a tank before the light comes on.
Ian P is offline   Reply With Quote
SV650 tank Cover hindle8907 Stuff Wanted 1 13-05-11 08:03 PM
SV650 K3 Fuel Tank Longway Stuff Wanted 4 26-02-10 08:42 AM
Curvy SV650 tank cover with tank bag mounts Paul M For Sale - SV's and SV related items 1 01-10-07 12:16 AM
Sv650 Tank Pads rob13 SV Talk, Tuning & Tweaking 14 05-11-06 11:44 AM
SV650 Tank Range alongwor SV Talk, Tuning & Tweaking 20 30-08-05 03:48 PM
