Old 24-06-10, 09:32 PM   #1
jonabonospen
Default Any simple front end swaps for a 1999 SV650SY ?
Got myself a 1999 SV650SY and I think the front suspension is garbage. It may be that it needs an overhaul, or it may be like this from stock, I really dont know. I just know that compared to my other bike, a ZX6R, the front suspension is soooooo soft it is ridiculous. It makes it feel difficult to ride fast as it is so wallowy (if thats even a word) that it just doesnt give you any confidence.
The other thing that has made me ask this is that I have also just bought some new front brake pads and tried to fit them tonight but when I have removed the old pads from the left caliper I have noticed one of the pistons is sticking, and the other one looks like the selas needed replacing. So before I do something to sort this I thought it may be a good idea to see if there is a front end swap you can do fairly easily.
Old 24-06-10, 09:35 PM   #2
Default Re: Any simple front end swaps for a 1999 SV650SY ?
SRAD is very easy
Old 24-06-10, 09:36 PM   #3
jonabonospen
SRAD is very easy
Can you elaborate on that at all or point me in the right direction for the details?
Old 24-06-10, 09:40 PM   #4
http://www.twfracing.com/vbforums/showthread.php?t=48
you need that conversion bearing, then just find a complete GSXR SRAD front end and it bolts right in.
The clipons for the GSXR are very low and may foul the fairing, so find some from a ducati SS or a TL1000S (not R) which are closer to the stock position.
You can use either 600 or 750 parts interchangeably depending if you want to pay extra for USD.
You will need a honeywell Gt101DC hall effect sensor and 4 magnets to make the speedo work.
Old 27-06-10, 02:29 PM   #5
ppbayeta
Junior Member
GSXR750W (92-95) is a remove and install change, maybe need some work on the ignition key, but anything important, bearings and clip-ons fits ok
ppbayeta is offline   Reply With Quote
Old 28-06-10, 10:08 AM   #6
I would say SRAD swap, or if the cash doesn't strech that far, 2nd hand rear shock and new front internals and refresh the brakes, but that works out at about 300- 400
The other route is to what Barwel has done and put a RSV mille front end on it is a damn sight more expensive as bearings need to be machined to suit http://forums.sv650.org/showthread.php?t=151525
Old 30-06-10, 09:25 AM   #7
1100 water cooler does not fit, lock stop is completely wrong. is it different on the 750?
I would not use those forks though TBH, they are pretty poorly set up.
Old 01-07-10, 02:50 PM   #8
ppbayeta
Junior Member
lock stops on 750 did not match, but is easy and simple put two M6 allen bolts on the down yoke to do it, i'm installing this front end now, you must put new lock stops and taped bearings on the SV neck, and maybe some work on the ignition key(nothing important), any more, yo mustn't buy especial bearings and keep the steering lock
But maybe the srad yokes be an interesting option, but you must buy the zoran bearing and it's 40€+shipping
PD sorry for my english, i'm from spain
1999-02 front wheel Lucas66 Stuff Wanted 0 29-07-09 01:08 PM
Simple (and I mean simple) Cake to make? krhall Idle Banter 32 14-04-09 01:04 PM
top bearing for front end swaps charlie13 SV Talk, Tuning & Tweaking 10 27-03-09 09:06 PM
4 simple jobs - 4 simple questions branny SV Talk, Tuning & Tweaking 23 18-02-09 07:36 AM
OFFERS: 1999 SV650SY myellow For Sale - SV's and SV related items 4 03-08-06 06:08 AM
