Old 28-06-10, 11:54 AM   #1
timwilky
timwilky's Avatar
Default too warm
The windows in this office do not open, the door leads onto a corridor, so no air movement, there is no air conditioning. I am sweating like a paedophile in mothercare.
Apparently the request for AC was rejected at the time we moved into this office by the landlord as too expensive
Not Grumpy, opinionated.
Old 28-06-10, 11:58 AM   #2
timwilky
timwilky's Avatar
Default Re: too warm
The facilities manager has just turn up to find out why we are complaining of the heat, he said there is a ducted air system, went to turn it on and it is already on.
Old 28-06-10, 12:05 PM   #3
L3nny
L3nny's Avatar
If it's over 30 degrees in our server room we have to turn off all the servers to prevent them from suffering heat damage.
Take a measurement, if it's over 30 then turn off all the computers and say you are worried about damaging them. After a couple of days of no productivity they will realise AC is cheaper.
2015 GS 1200 Adventure
Old 28-06-10, 12:12 PM   #4
Shonky
There is a maximum working temp you know under H&S!
Old 28-06-10, 12:14 PM   #5
L3nny
L3nny's Avatar
No maximum, only a minimum
http://www.hse.gov.uk/contact/faqs/temperature.htm
Old 28-06-10, 12:16 PM   #6
Shonky
Fair enough, I stand corrected
Old 28-06-10, 12:18 PM   #7
timwilky
timwilky's Avatar
Just been outside for a 5 min cool down, there is a lovely breeze blowing. Come back in and start leaking sweating
Old 28-06-10, 12:21 PM   #8
I've spent two days priming and painting skirting boards over the weekend, with added moving padding out front.
I am now pooped, and its way too hot, wish I had air con, but the internal central heating won't turn off
Old 28-06-10, 12:23 PM   #9
anna
anna's Avatar
You all complain of the cold weather and then you complain of the heat!!!!
Old 28-06-10, 12:24 PM   #10
L3nny
L3nny's Avatar
This thread reminded me to check the temperature of the servers and it's now at 30 degrees.
If it wasn't for this I probably would have forgotten.
The org triumphs once again lol.
Warm Welcome Owenski Idle Banter 11 16-03-10 10:37 AM
Warm up first? Kalessin Bikes - Talk & Issues 54 25-02-09 09:14 AM
To warm up or not to warm up.... DanAbnormal Bikes - Talk & Issues 21 16-08-06 04:30 PM
tyre warm up v's engine warm up? twotime SV Talk, Tuning & Tweaking 25 14-07-05 11:06 PM
Warm up BenScott SV Talk, Tuning & Tweaking 20 11-05-05 04:36 PM
