Racing and Paddock Chat The latest news, talk, and gossip from the world of bike racing, you can also discuss track days here too.
Old 30-06-10, 09:44 AM   #1
muzikill
muzikill's Avatar
Default New tracks using old airfields
A thread in svecosse got me remembering a site i found. It gives aerial views of all the old and current airfields in the uk. Thought i would post it in here & let you have a look and see if you can post a few we know & see if others can find a few fantasy potentials! (and play spot where it used to be - you can still see the outline in some of the aerial field shots)
http://www.content-delivery.co.uk/av...elds/regional/
as you can see there is quite a lot ...
http://www.content-delivery.co.uk/av...stFortune.html
here is scotlands 'other' lesser known track that uses an old airfield & is also home to our own concorde at the attached air museum.
http://www.content-delivery.co.uk/av...oss/Errol.html <-- thought i would stick this one in as an example (notice the go kart track tucked in the corner?)
http://www.content-delivery.co.uk/av...otsripton.html <-- this one if it wasnt so wasted by buildings would have been a belter.....
Tracks around Berkshire area... Matthie Racing and Paddock Chat 9 26-03-09 02:29 PM
Org Track Day Dates/Tracks Pt. 2 phil24_7 Track Days 35 02-02-09 12:14 PM
Org Track Day Dates/Tracks phil24_7 Track Days 30 02-02-09 12:14 PM
Any secret tracks about??? Demonz Guildford Massive 33 20-02-07 10:00 PM
Decent tracks...anyone know any? Anonymous South & West Surfers 9 23-05-05 07:30 AM
