Old 02-07-10, 12:17 PM   #1
Aidan
Default Low speed wobble
My K3's handlebars wobble at low speed if I take my hands off the bars - it's quite violent and the wobbling increases if I don't hold the bars. It's fine at speed and holding the bars lightly stops the wobble at low speed.
I assume if the wheel weights were wrong the wobble would increase as the speed got up? Could this be the head bearings? I checked the brakes and they aren't binding.
Would heavy bar end weights help? I couldn't fit normal weights onto the renthal bars.
Old 02-07-10, 12:24 PM   #2
_Stretchie_
Large Member
_Stretchie_'s Avatar
Default Re: Low speed wobble
As Mr Sid Squid would say "Don't let go of the bars"
Not very useful I know but I saw an opening and took it, plus I have the same on my BlackBird so will be watching this, the front wheel has just been balanced and that appeared to take the issue away
How to amuze an idiot:
Look right-> <-Look Left
Old 02-07-10, 12:48 PM   #3
Aidan
Damn, I meant to preempt that response and forgot!
Old 02-07-10, 01:51 PM   #4
Jayneflakes
Jayneflakes's Avatar
Mine does it when the front end goes light, is your rear set up correctly! Obviously I mean rear suspension. Go through the basics first. Both fork legs set up correctly, rear suspension unit set for your weight, wheel bearings in good order, brakes not binding, head bearing not notchy, forks not too far in or out of yokes, bar conversion not put you too far back?
Finally, what is the road surface like? That is as far as I know how to check I am afraid. Not much help, but I am just a girl with a K3 and am slowly taking it to bits as required. What about a steering damper if it is just poor roads?
Jayne you're a Pussy Magnet
Old 02-07-10, 07:20 PM   #5
Aidan
Hmm, I've only noticed it the last two times I've ridden it, both times were 300 mile sprints up the M1 with a fully loaded top box - maybe I'll see if its that.
Thanks
Old 02-07-10, 08:14 PM   #6
Weirdfish
Definately need to check your wheel bearings if the other advice doesn't sort it. Had the same issue, tried new tyre, balanced wheel then discovered the bearings were shot, replaced them and problem sorted! Happy days.
Jim
Old 02-07-10, 08:26 PM   #7
Biker Biggles
Biker Biggles's Avatar
"Fully loaded top box"
Hint hint say no more.
Old 03-07-10, 01:13 AM   #8
TSM
The Sick Man
TSM's Avatar
head bearings are suspect i would say on the top of it, all depends what you mean by low speed, under about 5-10mph the bike wheel will start to loose its gyro force and start to wobble around
wheel weights dont affect it like that, they would cause there to be a vibration but the bike will still naturaly want to go in a straight line
Old 03-07-10, 08:49 PM   #9
Razor
hear hear!
Old 04-07-10, 07:52 AM   #10
Aidan
Well the bikes MOT has now run out and I've forgotten to even book it in yet!
I pulled the bike up on the side stand so that the front wheel was off the ground and the head bearings seem fine. I'll take the front wheel off and check the bearings.
Oh and low speed I mean up to about 50mph.
bit of a wobble. AndyBrad Bikes - Talk & Issues 45 04-06-10 10:17 AM
Front end wobble ranathari SV Talk, Tuning & Tweaking 9 17-02-10 07:47 PM
Wobble and instability trev SV Talk, Tuning & Tweaking 11 01-08-09 09:08 PM
Had my 1st wobble last night Nobbylad Bikes - Talk & Issues 11 02-10-08 03:39 PM
High speed wobble SV1000 retrofly SV Talk, Tuning & Tweaking 9 16-05-06 09:52 PM
