Old 04-07-10, 07:42 PM   #1
Lozzo
Default Weird fault on SV at work this week.
A few weeks ago we sold this nice bloke and his missus a blue SV650 K9 that was immaculate, and within 2 weeks he'd dropped it quite heavily on the right side, with no crash bungs. Damage wasn't too severe and mainly cosmetic - very nasty scrapes all the way up both parts of the fairing, broken front brake lever and scraped can etc. The guy put a new brake lever on and continued to ride it as structurally it's safe and straight.
This week he phones us up because the bike won't start, it's completely dead. He was negotiating a roundabout when the bike died and there was zero electrics, Turning the key produces nothing, no dash lights... bugger all. Our mechanic went straight to the fusebox and replaced the 30A fuse, which immediately blew in a rather explosive fashion. Right, something has a direct short to earth, so further investigation is started. After unplugging this, testing that, sticking a multimeter on the other he finds the cause.
When matey had dropped the bike it shunted the fairing over a fair way, which in turn shunted part of the wiring loom over, which fretted on the coil bracket and resulted in the reg/rec cables shorting out and being fried about 30mm from the reg/rec itself. He managed to rework the cables and insulated them properly and then checked the reg/rec static readings with a multimeter... and it's fine. So plonked it all back together and did the usual charging checks with the engine running and it's back to normal.
Just one to bear in mind if you get the same on a pointy that's been slid heavily on the right side
Old 04-07-10, 08:08 PM   #2
muzikill
muzikill's Avatar
Default Re: Weird fault on SV at work this week.
same thing happened to me (kinda) fuse kept blowing and bike immobiliser would kick in, found out that the alarm loom had shorted against the bike due to vibration (when i checked the rear frame for the seat i found it to be raggy edged) p*ss poor it should have been filed down at the factory when made. Probably still the same with all of the pointys (worth checking if you do a strip down)
Cable was covered in tape to stop it happening again.
Weird happenings at work... speedplay Idle Banter 37 27-08-09 10:14 PM
Weird indicator fault - they became hazard warning lights RingDing SV Talk, Tuning & Tweaking 5 24-01-09 09:05 PM
Squires 28/05/08 - this week (not next week like gr33ks post) Paul the 6th Pennine Massive 20 28-05-08 05:15 PM
mid week? (first week october) hovis South & West Surfers 21 08-11-06 08:16 PM
how many hours per week do you spend at work? Dave The Rave Idle Banter 51 27-10-06 06:09 PM
