Old 05-07-10, 08:36 PM   #1
monkey
Default How can I fix a captive nut to the side of a radiator?
I need to somehow fix a nut to the side of a radiator. I was thinking a very quick weld would do but have been told it may ruin the rad.
The nut will be to support, not take the weight of, a radiator cowl. There will be a bracket top and bottom but this is for the bolt halfway down.
Would something like araldite on a suitably roughed up surface hold?
Any other ideas?
Thanks.
Old 05-07-10, 08:42 PM   #2
Nobbylad
Nobbylad's Avatar
Default Re: How can I fix a captive nut to the side of a radiator?
Liquid metal?
Old 05-07-10, 08:43 PM   #3
You could braze or silver solder one on, it will be a lot lower temp than weld as long as you make the area spotless it should be ok.
Downside is you need a burner, a pencil torch will keep the heat local.
A couple of good tacks would be enough.
Try the glue first, nothing to lose.
Old 05-07-10, 08:47 PM   #4
monkey
Ooh silver solder. I might just have some of that pre-fluxed stuff. I hear what you're saying about a tack. Could do them one by one with time to cool in between.
Keep 'em coming.
Old 05-07-10, 08:48 PM   #5
gettin2dizzy
Ask Y_C?
Old 05-07-10, 08:49 PM   #6
Keep 'em coming.
If you do one at a time, just make sure the other side isnt dirty before you start on it, they are notoriously bad to do if the area isnt spotless.
Old 05-07-10, 08:51 PM   #7
monkey
How do you mean other side? I just need to stick a nut to the side of a rad. I can get the rad back to bare metal.
Old 05-07-10, 08:58 PM   #8
Bluefish
Araldite should work, as long as you leave it 24hrs.
Old 05-07-10, 09:01 PM   #9
monkey
Tell you what I'll try araldite and then if that comes off I'll try silver solder. Like I say it's a support, somewhere for the nut to go and to stop the cowl flopping around.
Thanks fellas. See you all at the AR with my creation hopefully!
Old 05-07-10, 09:11 PM   #10
I meant if you do two tacks on the same nut but one at a time, you will dirty the area by doing first tack, so will need a quick clean prior to second tack.
Sorry mate for not explaining properly first time
Wanted RHS (Throttle side) radiator hose. weecorey Stuff Wanted 3 03-05-10 07:16 PM
Anyone got a left side rear set and side stand? Dhayn Stuff Wanted 6 17-08-09 10:08 AM
Radiator side things Horney For Sale - SV's and SV related items 4 25-09-08 07:34 PM
Left side? Right Side? lukemillar Idle Banter 23 16-03-08 08:07 PM
Get off the RIGHT side not the right HAND side DavieSV Bikes - Talk & Issues 15 12-12-06 06:19 PM
