Old 07-07-10, 12:44 PM   #1
metalangel
Default High water pressure all of a sudden??
I've lived in my house almost four years now so I know something's different.
-The water coming into the house seems to be at a higher pressure than it ever was before.
-The toilet tank refills with a loud BLAST of water that fills it twice as fast as before.
-The washing machine is louder whenever it lets mains water in.
-Taps are noticably more forceful when you turn them on.
-The power shower (draws water from the mains and runs through its own heating system) also is putting out more pressure (yay!) but again you can hear a lot more water going into it and faster too.
Is this anything to be concerned about? Or should I just STFU and be glad to have mightier water?
Old 07-07-10, 01:06 PM   #2
Default Re: High water pressure all of a sudden??
You do get fluctuations, but too bigger increase can blow seals on tap connectors, knacker up electric showers etc etc.
Just be vigilant.
I was working on a house yesterday (not plumbing) and the woman told me they have 7 bar of pressure feeding their house .
Normal for my neck of the woods is 2-3 bar, i've had to put a pressure reg in before as they had a wall mounted hot water heater that stated 5 bar max pressure and they had more than that.
Old 07-07-10, 01:33 PM   #3
metalangel
Spoke to Dwr Cymru who said I should have a stopcock in the house that I can adjust to control this. Told her that I might well do but I haven't a clue where it is and that any time anything has been done with our water (installing boilers, f'instance) the plumbers have gone outside to the one in the street with a long pole thing to turn it off there.
Was told I should have one in the house too, and if not, to get one fitted... but for now they'll arrange for someone to come and look as nobody else in the street has complained. In the meanwhile Mrs Metal is going to have a root around to see what she can find.
I'm just really frustrated as I spend my entire life sat behind this ferkin' desk and thus whenever something goes wrong there's little I can do as I have to be back in work again and so can't try and have a proper look myself.
Old 07-07-10, 03:24 PM   #4
Bluefish
You may need a pressure reducing valve fitting, as said over 3 bar can blow seals.
Old 07-07-10, 07:26 PM   #5
metalangel
Mrs Metal thinks she's found a stopcock under the sink which I will try adjusting when I get home.
Old 07-07-10, 08:58 PM   #6
arenalife
Reminds of the dirty joke where a Welshman is helping an Eskimo who has broken down at the side of the road, the mechanic says "I think you've blown a seal" so the Eskimo says "SO WHAT!! you **** sheep!!"
Anyway, try looking under the sink for the stopcock, sometimes it's down so low, it's below the level of the kitchen cabinet floor so you have to root around with the spiders. Sometimes it's in the downstairs toilet.
Old 07-07-10, 10:17 PM   #7
embee
embee's Avatar
The stopcock isn't really the way to deal with it, with no flow the full pressure will still be there.
I had the ball valve in my khasi burst due to the pressure. I picked up a Honeywell pressure reducing valve off fleabay for £15 and fitted it immediately after the incoming stopcock, everything is much more civilised now. Very simple to install.
Severn Trent seem to wind the pressure up here at 8am, the cisterns start dripping.
Old 07-07-10, 11:04 PM   #8
Screwfix sell them for £20
Old 07-07-10, 11:18 PM   #9
Nobbylad
Nobbylad's Avatar
The stopcock should reduce the flow of water into the house plumbing as it effectively reduces the gauge of the incoming water so that you will have the same pressure, but less volume. It's just the same as a tap.
IMO
Old 07-07-10, 11:23 PM   #10
beabert
yeah, just close the stopcock a little i keep mine closed a bit, infact are you sure no ones opened it recently, hense the increase.
Any plumbers about? water pressure nik_nunez Idle Banter 27 08-05-10 08:02 PM
Car Tyre Pressure way too high plowsie Idle Banter 20 17-07-09 10:29 AM
sudden highish idle? svscratcha SV Talk, Tuning & Tweaking 3 05-08-08 09:55 PM
High Blood Pressure Lissa Idle Banter 23 11-01-08 06:51 PM
High pressure weekend.... skidmarx SELKENT 7 06-11-06 11:42 AM
