Old 08-07-10, 08:53 AM   #1
emcf
Default Backfiring over bumps
Hi Folks
recently the sv has been having backfires when i go over reasonably big bumps in the road. it seems to only happen when the revs are up (6k and over). I've gone over the bumps in a higher gear at lower revs and no backfire occurs.
Connections to the battery and plugs seem nice and tight and I have no idea what else could be causing the problem.
anyone got any suggestions? scaring the tourists in central london with backfires is all good fun but I would prefer not to do it.
Old 08-07-10, 09:03 AM   #2
Default Re: Backfiring over bumps
Bypass the sidestand switch is a good start
Old 09-07-10, 06:30 AM   #3
ixlr8
Trouble with bypassing the sidestand switch is if you forget, the stand won't fold when you turn left. Forget it just once and you could well be dead. Not good outcome.
Things to look for are inadequate lubrication of sidestand so it doesn't return enough or, on older bikes, weakened springs, such as on mine.
ixlr8 is offline   Reply With Quote
Old 09-07-10, 06:54 AM   #4
TheShadow
Replace the 2 sidestand springs , this is what i did and it cured the problem.
Old 09-07-10, 08:47 AM   #5
Well in the majority of cases you'll just fall over and look a c**t... once you've done that once you won't do it again!
Old 09-07-10, 09:06 AM   #6
ophic
ophic's Avatar
Just to make sure it's that, I'd be tempted to tie the sidestand up then go for a bumpy ride.
Silver SV650SK3, Fuel exhaust
Old 09-07-10, 09:35 AM   #7
flymo
flymo's Avatar
take a good look at the connections in and around the bike on/off switchgear, particularly where the switchgear connects to the wiring loom just behind the headstock (you'll likely need to remove the airbox or pull the radiator forwards to get to this)
Old 09-07-10, 04:29 PM   #8
emcf
thanks folks
will give those suggestions a go. will ride it next week sometime as laid up on crutches right now
Old 09-07-10, 07:26 PM   #9
mikerj
Originally Posted by emcf View Post
thanks folks
Hopefully not as a result of leaving the sidestand down!
Old 09-07-10, 10:03 PM   #10
emcf
lol no! old age and rugby training combining to give me a torn calf muscle.
Crash.NET - Pedrosa: Estoril all about brakes and bumps. NewsBot News 0 28-09-09 05:10 PM
Those nice bumps along the motorway. Owenski Idle Banter 16 21-05-09 03:45 PM
Knocking over bumps AndyBrad SV Talk, Tuning & Tweaking 12 02-09-08 01:56 PM
Todays moan of the day. Bumps. ooger Guildford Massive 15 08-05-08 04:26 PM
Would You Like More Bumps With That Sir? RhythmJunkie Idle Banter 15 25-07-07 07:02 AM
