Old 10-07-10, 10:37 AM   #1
Paul the 6th
Paul the 6th's Avatar
Default Yoshimura rs3 race can on a gsxr750 srad - <101db?
Booked on bike magazine road bike only trackday at cadwell on 17th august - noise limit is 101db.
Will my yoshi rs3 race can (no baffles and no option to fit one) pass noise testing?
Picked up a cheap noise meter from ebay for £15 but turning it on and holding it in my hand registers around 60db, shouting at it is around 100db and holding 50cm from can at 45 degree is around 120 db. There's different types of noise meters and I get the impression I've got the wrong one
Old 10-07-10, 10:54 AM   #2
mikerj
Default Re: Yoshimura rs3 race can on a gsxr750 srad - <101db?
Does it have an 'A' weighted response curve? If so it should be correct - but of course the accuracy of a £15 instrument may not be great.
Old 10-07-10, 10:59 AM   #3
Paul the 6th
well this is the thing, it's maplins noise meter and I had a look through the book but couldn't see anything about it being type 'a' or 'b' as explained to me by a guy who does noise testing for bike drag racing at elvington in york...
Away from home til sunday so will have a look when i get back
Old 10-07-10, 02:36 PM   #4
nik_nunez
when they ask you to rev it to 7.5k just rev it to like 5k, wiill help a little,
Old 10-07-10, 03:44 PM   #5
mikerj
If you have the "mini" sound level meter from Maplin, then it's C weighting only I think.
Old 10-07-10, 04:06 PM   #6
Paul the 6th
that's probably the one - what's the difference between the weightings?
Old 10-07-10, 04:18 PM   #7
Mr Speirs
Mr Speirs's Avatar
Hey Mr the 6th!! If you go into the track days bit of this forum there is a similar thread about noise levels, I've just posted a explanation of all the weightings and some other info if you wanna check that out. Anything else you need to know let me know n I'll try answer it.
Linky doodle: http://forums.sv650.org/showthread.php?t=153972&page=3
Old 10-07-10, 05:34 PM   #8
mikerj
Wikipedia has a chart showing the response of the various SPL weightings. As Mr Speirs says, low frequencies are severely attenuated by an A weighted filter compared to C weighting.
Old 10-07-10, 05:51 PM   #9
paul a yoshi race can will be about 120 to 130 db.
You could alway go speak to a acoustics engineer and see if they could test it, be most accurate test possible
Old 10-07-10, 10:57 PM   #10
Mr Speirs
Mr Speirs's Avatar
Just done a small search...the cheap maplins SPL meter is C weighted.
You can safely assume that that meter will be over reading by a margin but probably not by the 20db you are hoping, if it were a V-Twin you might get close but an IL4 might be pushing it.
SRAD 750 forks and yokes. SRAD calipers. yorkie_chris For Sale - Other Bikes and General biking items 49 23-01-10 08:06 PM
Yoshimura TRS box c8omb SV Talk, Tuning & Tweaking 8 21-06-07 03:24 AM
srad gsxr750 front end wanted gruff Stuff Wanted 0 24-04-07 08:31 AM
GSXR750 SRAD Front End - Now Selling 21QUEST For Sale - SV's and SV related items 8 03-02-07 09:11 PM
yoshimura sv650s_guy Exhausts 13 24-02-06 10:58 PM
