Apparently I'm cursed and destined not to ride this year. I've recently had to replace the clutch rod oil seal that had started to leak very slightly after the chain snapped and took out the clutch rod. This meant removing the front sprocket and much fart-arsing around for a relatively simple job.
Once it was all put back together I took her for a test spin and all seemed fine until the end of the ride when I noticed a knocking sound and feeling at slow speeds. It's [very] audible from the right hand side and can be felt through the right footpeg. I have to say this issue was probably present throughout the ride, I just didn't notice it until travelling at creeping pace. The chain and sprockets are new obviously having been replaced when the chain snapped. This knocking/clonking definitely wasn't present until now so something I've done during the recent oil seal replacement has caused this. I've searched the forums and the suggestions tend to be chain tension/wheel alignment so I checked that to no avail. Today I've checked this for at least the third time and removed the rear wheel to check things closer and start from scratch with the chain tension but no joy. Just a few yards, literally, up the road and this clonking is there. I'm nothing more than a tinkerer and even then only armed with a Haynes so am no good with diagnosing problems. My initial thoughts were obviously around the front sprocket but in taking off the rear wheel today I noticed what I think is part #13 in this link: http://www.cmsnl.com/suzuki-sv650s-1...ist/97343.html was moving around inside its housing but I assume this would be held in place once the rear axle is put back in place. I also notice that the rear wheel doesn't spin particularly freely when the axle is done up to the correct torque (have just read the latest article in 'news' on the .org home page). I know it's difficult to diagnose stuff online so I'm just after any general thoughts/opinions really. I think my next step will be to re-do the front sprocket and double check that, unless someone here can think of another possible, particularly with the rear wheel, but bearing in mind this probelm wasn't there before and the old girl's barely been out this year. I just want to ride!! |
Collapsed rear wheel bearing? Or sprocket carrier bearing?
Is the knocking engine or drive train? In other words, does it follow the revs? If you rev the engine does it increase in speed or is it drive train where you pull the clutch in whist riding and it is constant? C |
Not engine as far as I can tell. It only does it while in motion but at slow speed (<20mph) and either stops or can't be noticed at higher speeds. I'm fairly sure it still does it while coasting with the clutch in at those speeds. I can't see/hear any issues just spinning the rear wheel on the paddock stand or while pushing it.
Cheers, Ryan |
Hmmmm, Well suspect #1 is stil rear wheel bearing or Sprocket carrier bearing.
Next option could be tight spots in the new chain hitting the swinging arm as they pass it. Or even front wheel bearings. What you don't want it to be is the final drive bearings inside the engine. That's not an easy fix. C |
What I can't get is how any of these things could happen when the bike's barely been used. It definitely wasn't a problem before I had the front sprocket off which is why can only think I've cocked something up along the way. You know how it is though once your mind gets working overtime and you start reading things!!
Are you sure part number 9 in the diagram is still there? It's basically a spacer between the sprocket carrier bearing and the rear wheel bearing. I've known it to fall out whilst people are messing around with their rear wheel and they haven't noticed, that would also explain why the wheel goes tight when you torque the axle up.
it does sound like a collasped bearing, but elimintate other possibilites like a fork knock if its the front end
Right, night shift number one out of the way, now back to this little gem! Thanks for the time taken to read and reply so far guys. With the rear wheel side of things, I only removed it yesterday, not during the original repair (replacing the oil seal) which only required the chain being slackened and lifted off the sprockets, so I don't see how any of the innards of it could have fallen out/been misplaced at that time - the knocking was there on the first test ride. I suppose it's feasible that the bearing could have imploded DURING the test ride but surely that's unlikely on a short gentle plod.
Anyone have any thoughts on what I could have cocked up/forgotten as far as removing and replacing the front sprocket? I've considered all the obvious stuff like too tight, too loose, backwards, inside out etc! If I go back to square one and re-remove and replace the f/s and nothing changes, how much of a job is it to renew the rear wheel bearing/s? It may well be in the Haynes but that's locked up in the garage and I need sleep! Thanks again so far - Ryan |
#9 |
A bearing can go at any time. Its still top suspect. Whip the rear wheel out and try each bearing with your finger to see if there's any roughness or notchiness. Also do the spriocket carrier
If it is a Wheel bearing its not a big job to repolace. Just drift it out from the other side and knock a new one in with a suitable size socket. If thats not it, Check spacers (again) and check sprocket bolts aren't touching the swinging arm. This could also be a sign of a very tight chain but I'm sure that that would have been evident. You didn't put a one tooth bigger front sprocket on without noticing or one link shorter chain? If its not those it looks like it'll be the final drive shaft bearings. ![]() There's nothing loose inside the front sprocket cover is there? C |
#10 | |
Nothing loose inside the sprocket cover, no. The final drive bearings [here comes my lack of knowledge ![]() |
Rear wheel/sprocket alignment | Nobbylad | SV Talk, Tuning & Tweaking | 5 | 09-02-11 07:13 PM |
Rear sprocket bolt size on 2nd gen SV650S? | Landshark | SV Talk, Tuning & Tweaking | 1 | 14-07-07 10:41 PM |
Rear wheel, sprocket, cush drive, disk. EBAY * NO RESERVE* | Bikerz | For Sale - SV's and SV related items | 0 | 21-06-07 11:06 AM |
URGENT! need a spacer for inbetween back wheel and sprocket | vsumouse | Stuff Wanted | 6 | 26-04-06 10:41 AM |
47T Rear Sprocket on a K4 SV650S | Valman | SV Talk, Tuning & Tweaking | 17 | 11-06-05 01:07 PM |
