Old 21-07-10, 07:08 PM   #1
Default Opinions please, especially engineering peeps - lowering pillion pegs.
Right long story short, wife would like lower pegs for pillion use so i have 2 options as i can see it, apart from changing wife or bike
Make a dogleg set of pegs that attach to existing mounting or
attach an ally plate of about 5mm thick onto mounting bolts of heel plate above existing footpeg, polish it up and attach a footpeg to bottom of it, plate will need to be jigged slightly to clear 'arm' .
There is already polished plates on the bike (see very bottom of pic) so it could be made to replicate this design.
I want it to look ok as well as be functional.
Here is a pic of a cardboard mock up i have done prior to drawing on cad14 in 2d.
Obviously, design could be modded if not quite right or anybody has any other good ideas or suggestions.
Thanks for any input.
Phil
Old 21-07-10, 07:27 PM   #2
mjc
Default Re: Opinions please, especially engineering peeps.
cant remember how pillion pegs are mounted to rear subframe on sprint, but if theyre bolted why not add spacer (something like 5mm ally as you suggest) between subframe and peg mounts. start with a big plate, try different mounting holes and cut down to size when youre happy with the position.
Old 21-07-10, 08:02 PM   #3
Bluefish
Not sure the cardboard will work mate, i know it's corrugated for strength but it's not even waterproof ffs LOL
Old 21-07-10, 08:04 PM   #4
Cheers, you have spotted a design flaw already, what am i like
Does your OH find the st pegs ok?
Old 21-07-10, 08:04 PM   #5
Holdup
Cling film
HTH
Old 21-07-10, 08:06 PM   #6
Some more serious opinions as well please not just p1ss taking
Old 21-07-10, 08:08 PM   #7
if they aint cast into the subrfame either space it or fab a drop plate for it
Old 21-07-10, 08:16 PM   #8
Thats what the carboard mock up is, a drop plate, the actual mounting is a big cast piece mounted onto rear frame, you can see it in picture so cant do anything with that.
Old 21-07-10, 08:22 PM   #9
try and utilise the peg hole attaching the braket there
Old 21-07-10, 08:27 PM   #10
Well, if i made a dogleg peg then i would, but i couldnt attach the ally plate there, not enough to attach to, also want the bike to be able to be put back to stock.
shorter pillion pegs? 2hys SV Talk, Tuning & Tweaking 3 30-11-09 06:07 PM
400/450 Enduros with pillion pegs? lukemillar Bikes - Talk & Issues 6 28-07-09 05:24 AM
R&Gs ...how to fit? and pillion pegs? [JP] Bikes - Talk & Issues 24 01-09-08 11:33 AM
curvy pillion pegs- full set Quiff Wichard For Sale - SV's and SV related items 4 27-05-07 09:56 PM
Floppy pillion pegs Muttley SV Talk, Tuning & Tweaking 8 17-02-06 12:14 AM
