Old 24-07-10, 03:03 PM   #1
kd80
Angry Next problem: tachometre not working after airbox removal
Hello everyone.
I'm really getting annoyed with my bike now. The next problem: after removing the airbox the bike's tachometre is not working. I fired the bike up and the bike seemed quite rough. But that could be down to my exhaust which is busted at the moment and requires a new one.
I removed the airbox (with quite a struggle) and I took a look at the idle adjustment screw. I did not move it much since it appeared to be siezed but in fact it was not.
So, re-installed the airbox and started her up when I noticed the problem occur. The panel itself is working - the odometre is displaying along with the light panel. Just not this. I want to give my bike a complete overhaul but I do not think it is wise at the moment. I just want to get it working since I move soon and need to transport the bike (preferably by riding it).
So p**sed off right now.
Old 24-07-10, 03:17 PM   #2
Default Re: Next problem: tachometre not working after airbox removal
You knocked the wire off of front coil?
Old 24-07-10, 03:21 PM   #3
kd80
Not too sure. Not as far as I am aware.
Where would I be looking if so?
Old 24-07-10, 03:40 PM   #4
Left side of bike, bolted to frame rail near where crank breathers go onto airbox. Very likely culprit.
Old 24-07-10, 03:41 PM   #5
kd80
Thanks - I'll take a look. Hopefully it is that. I had some difficulty getting the airbox pipes on that side - one was a right bitch to get to!
Hoping I knocked it while trying to connect and it's just a simple reconnection.
Old 25-07-10, 08:44 PM   #6
kd80
Hi Chris, I've just taken a look inside the bike and I guess I have found it; I have attached the image which I hope is it. Could you confirm?
Old 25-07-10, 11:17 PM   #7
Yup that wire, you knocked it off coil.
Speedo not working after wheel removal. Irksy SV Talk, Tuning & Tweaking 2 28-06-10 05:14 PM
speedo not working, any sugestions on the problem? barwel1992 Bikes - Talk & Issues 40 27-10-09 05:18 PM
Chain buffer removal requires swing arm removal :-( 2mths SV Talk, Tuning & Tweaking 1 09-07-07 09:19 AM
K3 airbox markmoto SV Talk, Tuning & Tweaking 2 30-06-06 10:29 AM
Airbox Removal K4 PoRk ChOp SV Talk, Tuning & Tweaking 3 21-02-06 08:20 AM
