Old 25-07-10, 02:41 PM   #1
SAMMY650
Default How much will GSXR600 K6 Shock lower Sv?
I've had a look through alot of the threads already on here about fitting different shocks to the sv.....
My question is, if I fit a GSXR600/750 K6-9 Shock onto my K6 SV650S will it effect the ride height at all as the GSXR shock is listed as 10mm shorter than stock? Is it as simple as it will lower it by 10mm??
Thanks
Old 25-07-10, 02:51 PM   #2
Default Re: How much will GSXR600 K6 Shock lower Sv?
yes
Old 25-07-10, 04:52 PM   #3
Whitehouse
I had a k7 750 shock on mine before, which i think is similar to the one your looking at, and the shock was 13mm shorter than stock and it made it quite a bit lower. I didnt like it due to it affecting the responsiveness of the bike, wasnt as flickable into corners as stock
I believe that if you install a shock thats 13mm shorter it lowers the bike more, i think it was around 30mm difference in ride height
Old 25-07-10, 04:55 PM   #4
barwel1992
yes it will drop the back of the bike 20mm (1:2 ratio) it will also make the bike handle pretty slow
Old 25-07-10, 10:18 PM   #5
SAMMY650
So would I be better off with a shock that is actually longer than the 330mm stock (eg. the ZX10R shock)?
Might be a stupid question, but why does it double the measurement?
Old 25-07-10, 10:59 PM   #6
barwel1992
yeh the zx10r shock is good
not sure its to do with the linkage ratio
GSXR600 K2 shock in K5 SV650? tiernanobrien SV Talk, Tuning & Tweaking 1 01-09-09 03:50 PM
gsxr600 k4 shock fitted skeetly SV Talk, Tuning & Tweaking 9 08-04-09 10:11 AM
GSXR600/750 K6 shock. Does this fit a pointy? zsv650 SV Talk, Tuning & Tweaking 15 25-01-09 08:14 PM
GSXR600 K2-3 shock - suitable for a pointy SV? rude SV Talk, Tuning & Tweaking 10 17-01-09 05:57 PM
Valve clearances and gsxr600 shock settings fatmanracing SV Talk, Tuning & Tweaking 2 17-11-05 09:44 PM
