Old 29-07-10, 01:55 PM   #1
Elltg
Default Side stand cut out in neutral?
I recently tried wiring a neutral light in off the loom using an led with a built in resistor and it worked fine but then as I was working on other parts I snapped the leg of the led and I think it either shorted or kept sparking or something and now that doesn't work and my bike stalls if I put the side stand down even in neutral. Did I blow some fuse somewhere?
Old 29-07-10, 03:31 PM   #2
Default Re: Side stand cut out in neutral?
have you removed the parts you spliced in and tried?
Old 29-07-10, 03:39 PM   #3
Elltg
Yes in the end i gave up with them and made sure everything was insulated with tape and everything. Its the way the line just seemed to stop working that confused me!
Old 29-07-10, 03:42 PM   #4
have you looked at the switch on the stand.
They can stick in a position due to being blasted with road sh*te
Old 29-07-10, 03:49 PM   #5
Elltg
Well that switch operates fine. It cuts the engine out, yet it never used to do so when the bike was in neutral.
Thats my issue.
It means I cant let the bike warm up whilst putting on my gear. Also when I come or go I have to open the door before I start to warm the bike up not a huge nuisance but when I get back I have to turn off the bike (as I have to sit the bike on the stand) to open my garage door, but it is sloped up into my garage so I drive the bike back in meaning I have to start the bike again and then stop it again I'd rather not have to do that to my battery/bike if I don't have to.
Anyone got a left side rear set and side stand? Dhayn Stuff Wanted 6 17-08-09 10:08 AM
Non starting after side stand cut out. woodizmo Bikes - Talk & Issues 6 13-06-08 10:06 PM
Side Stand Giffer2 SV Talk, Tuning & Tweaking 3 23-06-07 07:38 PM
Storage: Side stand or rear paddock stand? Maudster SV Talk, Tuning & Tweaking 19 20-01-07 04:45 PM
Side stand Tris SV Talk, Tuning & Tweaking 6 17-10-04 12:12 AM
