Hi all.
I managed to strips 3 of the 5 bolts attaching the rear sprocket to the rear sprocket drum. The nuts are turning loose on the bolts and cannot be removed. Stupidly enough, I smashed onto one of the nuts, trying to get it off. Didn't work. Then I noticed some cracks in the alu drum house, more specifically connections to the bearing house; see on attached pics. I'm afraid this could be the result of the smashing. Don't know if they where there before. Is there sbdy who can check on his rear-sprocket drum to see if these cracks are genuinly present and thus result of normal machining? What do ya think gentlemen, can I remount & drive with this sprocket-drum, or will it be torn to pieces and eventuallly kill me? Tx, Phil the sprocket & drum; red circles indicate where cracks appear: http://i265.photobucket.com/albums/i.../DSCN2953e.jpg cracks close-ups: http://i265.photobucket.com/albums/i.../DSCN2948e.jpg http://i265.photobucket.com/albums/i.../DSCN2949e.jpg http://i265.photobucket.com/albums/i.../DSCN2950e.jpg http://i265.photobucket.com/albums/i.../DSCN2951e.jpg http://i265.photobucket.com/albums/i.../DSCN2952e.jpg Last edited by philbond07; 03-08-10 at 10:46 PM. |
The Sick Man
looks like casting defects to me, not 100% sure, i dont think its much of a problem though
if the bolts are just spining you will need to push the bolt part from the back of the hub so it stops spinning as you undo the nut
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
evilbay usa 300450743675
or http://shop.ebay.com/i.html?Model=SV...h+drive&_rdc=1 peice of mind priceless |
they do look like casting marks, but without seeing first hand I wouldn't like to diagnose from those images, and as you don't have your location in your profile, not much chance of anyone popping over to have a look for you either
Tip for you: Next time a bolt is spinning freely, look at the back of it and find out why BEFORE you smash f*ck out of it with a hammer.
QUOTE=davepreston;2335808]evilbay usa 300450743675
or http://shop.ebay.com/i.html?Model=SV...h+drive&_rdc=1 peice of mind priceless[/QUOTE] Hey dave haha yes you're right, great link; this will surely be option when I cannot be reassured finally. Only problem is getting the stuff shipped to Belgium. |
Right, profile updated. I'm getting old.
#9 | |
Why the bolts/nuts are stripped? Cause I torqued them to 60 Nm as the manual prescribes, which is much too high for this type of bolt. Max. for 8.8 M10 is like 47 Nm. Only found this out post-damage of course. Appreciate your reaction TSM. Not sure though if the cracks are casting defects or induced by hooliganism. If I can find another case of oem-cracks, say on one of yr sv's, then it would look like just cast-defects. Last edited by philbond07; 04-08-10 at 07:42 AM. |
#10 | |
Just wanted to try get them out before taking a grinder; have no access to a nut-cracker. But what do you think of the sprocket drum "cracks"? Is there someone of you gentlemen who is able to check out yr sprocket drum and see if these "cracks" are moreorless genuine? Would be great moment to clean-up that rear-wheel. Last edited by philbond07; 04-08-10 at 07:51 AM. |
Rear sprocket, which way? | DavieSV | SV Talk, Tuning & Tweaking | 0 | 12-05-08 10:40 PM |
Rear Sprocket | plowsie | SV Talk, Tuning & Tweaking | 3 | 05-06-07 07:46 PM |
Rear Sprocket | SVNutta | SV Talk, Tuning & Tweaking | 3 | 06-09-06 02:49 PM |
47T Rear Sprocket | bobit69 | SV Talk, Tuning & Tweaking | 39 | 26-03-06 10:53 AM |
46T REAR SPROCKET | 21QUEST | SV Talk, Tuning & Tweaking | 1 | 23-09-04 09:18 AM |
