Old 11-08-10, 04:51 PM   #1
widget
Default sv650 k3 39k miles or will split for parts
im buying a front end damaged sv1000 (head light front fairing and afew scuffs here and there) and using all the body work from my one to rebuild the thou. the thou will be stripped and use the body work thats good from it to build the 650 and sell complete for £1300 if any one is interested.
heres the sv650 please note none of the panels will be sold from this bike maybe the front mudgaurd if it doesnt fit
and heres the thou to give you an idea of colour and damage to the surplus parts i wont be using
failing the complete bike selling ill split it if 90% of it will sell ill be getting interest from everyone first.
micron down pipes 1 month old with scorpion street extreme end can with custom link pipe to pipe the down pipes £250
rear wheel, disc, sproket 45 teeth and tyre pilot power 3mm to the marker powder coated gloss black £140
front wheel pilot power 2ct tyre 3mm to the marker powder coated gloss black £100
pyramid hugger sprayed gloss metalic black £40
front discs 4.4mm left on the disc straight and true £60
front forks had a service 1k miles ago slight rust on lower yoke, front spindal, top yoke powder coated gloss
black with key marks to finish £200
clip ons straight no damage £30
lock set with spare key £50
front calipers master cylinder and reserviour with galfer braided hoses £50
rear caliper master cylinder and reserviour standard line £30
rear caliper mount power coated gloss black £20
frame and v5 no finance outstanding cat D £70
swing arm with spindal and linkage £40
rear subframe freshly powder coated silver so no rust £90
rear pillion pegs powder coated silver £20
engine 39k on the clock no problems what so ever with it the clutch doesnt slip theres no leaks or drinking oil problem
fresh oil and plugs every 5k the normal tick fron the cam chain tensioner. comes with worm drive, cover, front sproket,
radiator with grill (bent but no leaks) oil radiator, air box with k&n air filter, ht leads £400 (can split if needed)
full wiring loom £60
ecu £50
rear shock £30
clocks 39k on them £80
these parts are to be confirmed as they are coming from the other bike which is a k4 in the dark blue
tank with sv650 fuel pumpdark blue colour £90
rear fairing panels complete £60
lower fairing scuffed but not too bad £50
damaged headlight scuffed on the lens £30
Old 11-08-10, 09:20 PM   #2
philpy008
Default Re: sv650 k3 39k miles or will split for parts
Hi mate sounds an interesting project might be intersted tho i aint to sure what it is ull be selling lol (bit slow in know ) any help appreciated.
Old 11-08-10, 11:28 PM   #3
widget
Ill be selling all that is listed with a price
Old 12-08-10, 12:35 AM   #4
Ratty
Ratty's Avatar
For info... Your 650 lower fairings will not fit the thou.
Ratty
"I can see Paradise by the SV's light"
TCX Competizione S boots saved my foot .
Ratty is offline   Reply With Quote
Old 12-08-10, 06:38 PM   #5
philpy008
Are you selling the 650 whole
Old 12-08-10, 07:44 PM   #6
widget
Yeah its all in the listing dude
Old 09-11-10, 06:02 PM   #7
tommy-d
are you selling the fuel cap off the tank?
Tom
Old 09-11-10, 06:19 PM   #8
davepreston
i'll have this dependant on condition and pics
cheers
dave
ps i wont need the fuel cap so you can sort something out with tommy
Old 09-11-10, 08:24 PM   #9
skithepowder
1st dibs please, depending on when and if you decide to break.
Old 10-11-10, 10:22 AM   #10
widget
This thread is out of date the sv thou I was gonna get went so this thread is now useless
WANTED: '99 sv650 parts or for parts moonshiner_19 Stuff Wanted 5 26-08-18 12:54 PM
Buying advice please - SV650 'T' Reg, 13,000 miles magicdaz SV Talk, Tuning & Tweaking 19 30-05-10 09:15 AM
K6 SV650 S '07 Mint, Low Miles josh For Sale - SV's and SV related items 4 28-05-10 10:19 PM
K8 SV650 S 1,200 miles DjacK For Sale - SV's and SV related items 8 08-07-09 03:30 PM
07 Sv650 3000 miles shaneo For Sale - SV's and SV related items 3 30-04-09 12:22 AM
