Old 30-08-10, 08:39 PM   #1
cringer
Default Uneven chain stretch - how much is OK?
If a chain is 55mm slack at one position and 35mm at another does this mean it's ****ed? I still have room to adjust it but I'm wondering wether i should invest in a new chain
I try to keep it at 40mm slack btw
Old 30-08-10, 10:04 PM   #2
davepreston
Default Re: Uneven chain stretch - how much is OK?
stiff link lube properly
Old 31-08-10, 07:10 PM   #3
Biker Biggles
Biker Biggles's Avatar
I would say you adjust it correctly at the tightest part,and if that results in way too much slack in other places its fooked.Also worth looking at the amount of lift you can get on the rear sprocket and the condition of the sprockets.
Old 31-08-10, 09:44 PM   #4
rob13
Check for play within the links themselves by taking the back wheel out.
Old 31-08-10, 09:48 PM   #5
Clean it, adjust it, replace it.
Old 02-09-10, 12:24 PM   #6
warrenhewitt10
yeah id give it a good proper clean, its amazing the difference it can make. But granted ive had a few chains that get that annoying tight spot in them, a clean doesnt fix it, but it will get a good few more miles out of it. Scottoilers are the way forward havnt cleaned my chain in over 4000 miles and its still spotless
Old 02-09-10, 12:46 PM   #7
AndyBrad
Scottoiler doesnt mean you sholdnt clean your chain though, just takes the lubing out of it.
Old 02-09-10, 12:48 PM   #8
Really?
I clean mine when it gets dirty. Not happened yet!
Old 02-09-10, 01:30 PM   #9
AndyBrad
Hmm mine did. Thourght you still had to clean the crap off it tho. Happy to be told otherwise...
Old 02-09-10, 01:32 PM   #10
Viney
My chain is 25 mm at tightest spot and 130mm and loosest, its well broken, so much so it 'surges' at low speeds Off for a new one this evening
Irregular chain stretch SVMAT SV Talk, Tuning & Tweaking 14 06-05-10 10:34 AM
Uneven chain wear rockster SV Talk, Tuning & Tweaking 17 16-05-09 08:03 PM
New chain - stretch? lukemillar Bikes - Talk & Issues 10 16-08-08 12:29 PM
Uneven wear.. StreetHawk Tyres 5 29-04-07 09:42 PM
Chain Stretch squirrel_hunter Bikes - Talk & Issues 6 23-11-06 03:49 PM
