just wondered cos im thinkin of goin wider on next tyre change, just to see,
Just to see what?
If he knows more/better than the engineers at Suzuki, obvious really...
Could always just stick a car tyre in there and be done with it...
Sent from my PC NOT using any Tapatalk type rubbish!! █╬╬╬╬(•)i¯i▀▀▀▀▀█Ξ███████████████████████████████) |
#5 | |
If you want to go wider, then search for threads on doing it properly by changing the rear wheel for something else.
i think irksy put a 180 tyre on his rear but pm him to be sure and ask what he thought
No reason to do it, it makes it a bit odd. Hard to describe how.
Only reason I tried it is because I had a puncture and a 180 kicking about.
#8 | |
I'm fairly sure I know more than the engineers at suzuki about my use of the bike... hence why I've modified it to suit that use. I'm of opinion that you should use a different wheel if you want 180 on there, there are more choices of compound and cheap scrubs in that size which is nice.
140mm dogbones - 6mm shorter than stock - raises the rear end by 0.5 - 1 inch | Stu | For Sale - SV's and SV related items | 6 | 11-06-07 10:32 AM |
Mix a stock D220 front with a Z6 rear? | monkey | SV Talk, Tuning & Tweaking | 19 | 19-02-07 07:45 PM |
Largest UK Team @ WSB Is... | Mike1234 | BSB & WSB | 24 | 10-01-07 03:50 PM |
GSXR rear shock stock spring rates | lukemillar | Bikes - Talk & Issues | 3 | 07-05-06 01:38 PM |
Largest object buried? | rubberduckofdeath | Idle Banter | 13 | 16-03-06 04:33 AM |
