Mini-Twins Goto Minitwins Official Site
Old 30-09-10, 10:01 PM   #1
thmjo1
Default Gearing for Aintree
Hello all,
can anyone suggest what gearing I need on an 06 SV for racing at Aintree? Cheers
Old 05-10-10, 07:23 PM   #2
thmjo1
Default Re: Gearing for Aintree
Anyone?
Old 05-10-10, 07:23 PM   #3
thmjo1
Please
Old 06-10-10, 08:53 PM   #4
Berlin
No replies would indocate that either no one knows or it doesn't matter.
Just run standard (15/44 or 45) and change if you find a need to.
C
Old 06-10-10, 09:00 PM   #5
thmjo1
Thanks Berlin. Bike has 14/45 fitted so will swap the 14 for a 15 and see what happens!
Thanks again
Old 06-10-10, 09:12 PM   #6
Berlin
Don't bother changing it until you've riden there. You can always change gearing betwene practices.
Just go with 14/45 and see how it is. if you have a dodgy gear change position in a bend or are topping out in 6th then change but I'd just go with what you have on until you've seen if you need to change..
C
Old 07-10-10, 04:52 PM   #7
eldiablo#75
Hi, i ran standard gearing there last month(15/45) and was on the limiter half way down the back straight and having to back off,so i wouldnt run the 14 front,if i do the next meeting il be putting a 44 on for that few extra mph..hope this helps pal
Old 07-10-10, 05:05 PM   #8
hardhat_harry
Its got one of the longest straights in the country, standard gearing I would say.
Old 07-10-10, 09:20 PM   #9
thmjo1
Thanks all. I'll go with 15/45 and see what happens. Probably a bit irrelevant as this is my first meeting so I'll be wobbling around at the back trying to stay out of trouble!
Old 09-10-10, 10:56 AM   #10
eldiablo#75
good luck mate,iv just rang up and entered myself,so il be wobbling round somewhere near you then! what number you running il keep an eye out for you,im 75,orange bike
gearing for aintree eldiablo#75 Mini-Twins 0 09-08-10 05:45 PM
Gearing leon#51 Mini-Twins 1 24-12-09 09:45 AM
gearing ophic Bikes - Talk & Issues 2 27-06-06 03:54 PM
gearing ujoni08 SV Talk, Tuning & Tweaking 5 06-04-05 04:39 PM
Gearing.. Yams SV Talk, Tuning & Tweaking 6 20-03-05 10:43 PM
