Old 11-10-10, 03:16 PM   #1
FG1
Default Numb hand - Pointy.
OK, before I start I will let you all know that I have the levers set at an angle that is ok for me.
Lately I have noticed that my right hand, and only my right hand, gets numb with a pins and needles type of sensation after riding for a short while. A handy thing some might think, but that's for another situation...
I am not too sure what could be causing this but thought I would ask if it could possibly be a bar end. I have R&G's and they appear to be done up nice and tight.
Would it be worth taking the bar ends off completely and seeing if that makes a difference.
I have a K8 naked with pretty much flat Renthal bars with a bit of sweep.
Old 11-10-10, 03:30 PM   #2
Jimmy2Feet
Default Re: Numb hand
I have the same issue, again only in my right hand, and on every bike i have ridden, but i only get it when i am using my winder gloves. Summer gloves not an issue.
Old 11-10-10, 03:30 PM   #3
Jimmy2Feet
Winter Even
Old 11-10-10, 04:11 PM   #4
LankyIanB
Is it all of your right hand or only part of it? If you have issues with the nerve that runs through the back of your elbow joint, you'll have issues with pins and needles in your litle and ring fingers.
If it's the whole hand, see if you can relax a bit with your grip. You only need to grip enough between thumb and forefinger to hold against the throttle springs. Steering is mostly push (you can pull too). But Push doesn't need grip.
Old 11-10-10, 04:37 PM   #5
I have posted this many times, check your cuffs and gloves arent done up too tight, i found this out the hard way.
You want them just nice and free, not tight at all because when your wrists are angles the cuffs etc get tighter.
I dont get this at all, but if rode tomorrow with the cuffs and gloves tight i would get pins and needles within 30 mins.
HTH
Old 11-10-10, 05:36 PM   #6
the100thidiot
HTH
+1. I used to get this now and again, but after someone suggested it might be caused by tight gloves I made sure I left a bit of slack and its not happened since.
Old 11-10-10, 06:03 PM   #7
BBadger
Also check your not gripping the throttle to hard. use more of your fingers rather than thumb and 1st finger by spreading your hand out across the entire grip, made a world of difference to me but keep having to remind myself to do it.
Old 11-10-10, 07:36 PM   #8
jay987
its your weight on your wrists, i get on long rides if sit in one psition for long periods of time, i get it in both hands but worse in the right due to i smashed my shoulder three years ago, plus my small finger and third finger goes white and cold.
Old 11-10-10, 07:48 PM   #9
FG1
TBH, i dont grip it tight, I dont lean on my wrist and my glove and jacket arent tight.
Old 11-10-10, 08:46 PM   #10
Messie
The Teacer
Messie's Avatar
Default Re: Numb hand - Pointy.
You should get a fairing, keep the wind off!
Right Hand Mirror for Pointy Shellywoozle For Sale - SV's and SV related items 5 26-07-10 11:02 PM
How much for a 2nd hand pointy tank? lazymanc SV Talk, Tuning & Tweaking 2 12-04-09 04:19 PM
Right hand mirror for pointy. Seggons Stuff Wanted 0 30-11-08 09:36 PM
right hand goes numb jans1971 Bikes - Talk & Issues 30 30-09-08 11:28 AM
Left hand mirror Pointy K3? Tallguy Stuff Wanted 1 19-08-08 09:34 PM
